Head gasket gone
- westonwarrior
Re: Head gasket gone
at least you can be reasonably sure your car will be as good as new again and will last for many years
That is how I look at it. It is in very good nick and undersealed so it should do.westonwarrior wrote:at least you can be reasonably sure your car will be as good as new again and will last for many years
						- mikexgough
I hope it works out well for you,,,,you mention future mods like a Mason/gauge mod and a high level alarm, I take it you have a low water alarm already as you didn't mention it warning you at all....
Yes it has a low water alarm but it didn't activate because the pressure caused the expansion tank level to rise.mikexgough wrote:I hope it works out well for you,,,,you mention future mods like a Mason/gauge mod and a high level alarm, I take it you have a low water alarm already as you didn't mention it warning you at all....
I think a true reading temperature guauge might have helped over the long term because I honestly think I have driven this vehicle too hard on many occasions
						- haydn callow
unfortunatly ..in some cases it is possible to overheat a engine without coolant loss (i.e. blockage/failed pump/failed head gasket) that is where a LCA/temp gauge combo is a bonus.
A Hi-Alarm would also not have prevented this as the damage has to be done before the coolant fills the tank.......
Just one of those cases where no amount of gadgets would have pre-warned i'm afraid.
Hope you get it sorted very soon
Thanks Haydn, if nothing else I have learned an awful lot about liquid cooling systems, not least how much I still have to learn! ADS have got their best man on the job so it should be good when I get it back and I will treat it with a bit more respect for its age.haydn callow wrote:unfortunatly ..in some cases it is possible to overheat a engine without coolant loss (i.e. blockage/failed pump/failed head gasket) that is where a LCA/temp gauge combo is a bonus.
						- missfixit70
Got to disagree here Haydnhaydn callow wrote:unfortunatly ..in some cases it is possible to overheat a engine without coolant loss (i.e. blockage/failed pump/failed head gasket) that is where a LCA/temp gauge combo is a bonus.
A Hi-Alarm would also not have prevented this as the damage has to be done before the coolant fills the tank.......Just one of those cases where no amount of gadgets would have pre-warned i'm afraid.
this may come as no suprise to some,but i have to agree with  miss f.
the high alarm is a very good bit of kit. as this can detect a pressure rise due to a small (undetected) coolant leak in the system earlier than normal temp gauges do.
I rang the garage tonight as I needed to know the mileage for my insurance renewal and they had it running and were out road testing!
						- missfixit70
Good news
 , just in time to get up to the bash
See how it goes.missfixit70 wrote:Good news, just in time to get up to the bash
I bet I've got to anyway to fit the temp alarmlazyb5 wrote:If I can undo the dash without breaking it anybody canI have fat fingers
						- mister munkey
Velocette wrote:See how it goes.missfixit70 wrote:Good news, just in time to get up to the bash
It is being MOTd Tomorrow, another prayer to Ahura Mazda needed.
And a temp alarm on order! Looked at doing the guage mod, I'm fine with the electronics but I don't want to pull the dash apart I'm clumsy with trim.
Its not too daunting.
Drop the steering wheel with the lever on the column, look for the Phillips screws to remove then GENTLY pull the binnacle out, being careful not to disturb the rest of the wiring back there.
Once its out, it all makes sense.
Cheers. I'll probably do the resistor and shunt trick as well then.mister munkey wrote:Velocette wrote:See how it goes.missfixit70 wrote:Good news, just in time to get up to the bash
Passed the MOT by the way, straight through only adisory was rear seat folded couldn't test fully. Bloody good job too!
