Probably agree with that Haydn, but the query here is 'what does the small pipe actually do'? What's it for?haydn callow wrote:I do know that if the pipe was not there the coolant alarm sensor would not work in the position we now fit it.
Pipe - expansion tank to heater circuit return
- widdowson2008
Re: Pipe - expansion tank to heater circuit return
Steve
- haydn callow
Well !! one thing it does do is allow coolant to flow "through" the ex tank......thus allowing it to be a degassing tank....perhaps that is all it is there for......
- widdowson2008
Reckon you are right there. Sounds logical to me.jaylee wrote:Does it allow trapped air in the heater matrix's exit the system during bleeding...? & when running some sort of pressurized equilibrium in the header tank, so when cold on a relatively healthy system coolant levels can be checked more accurately??
Maybe i worded that wrong..!Just avin a crack at a guess..
Steve
- widdowson2008
That's a thought. Could the reason for the small diameter exit pipe be to DELIBERATLY slow down the flow through the tank to allow more time for the tank to de-gas?haydn callow wrote:Well !! one thing it does do is allow coolant to flow "through" the ex tank......thus allowing it to be a degassing tank....perhaps that is all it is there for......
We know that any air in the system HAS to go through the head, main radiator and expansion tank (because of flow direction), so to slow the flow at this position to allow air more time to escape makes total sense.
Steve
One question... Why would the word "booster" be written on the front of the header tank...?
- widdowson2008
'Booster'? Where's that then?jaylee wrote:One question... Why would the word "booster" be written on the front of the header tank...?
Steve
- haydn callow
not on any of the half dozen I have.....is it just a sticker ??
After a massive service early last year... "booster" was written in black marker pen on my header..? Now i currently have a P reg metallic light greenaft 2.5 derv 4x4 on my drive..widdowson2008 wrote:'Booster'? Where's that then?jaylee wrote:One question... Why would the word "booster" be written on the front of the header tank...?
- widdowson2008
Can't you ask the garage what 'booster' signifies? I'd be interested for one.
Perhaps it may mean that the coolant mix has been strenghened by topping up with antifreeze
See if you can find out.
Steve
- missfixit70
Have they both got Mason alarm mod mebe?jaylee wrote:After a massive service early last year... "booster" was written in black marker pen on my header..? Now i currently have a P reg metallic light greenaft 2.5 derv 4x4 on my drive..widdowson2008 wrote:'Booster'? Where's that then?jaylee wrote:One question... Why would the word "booster" be written on the front of the header tank...?on loan while a well known Bongo garage in my local takes care of the fuel pump seal leak... (I just couldn't be arsed after looking up the subject.) looking the P reg over... "booster" same place same handwriting!!
- widdowson2008
What's the connection between Mason alarm and Booster?
Steve
- missfixit70
Just trying to think outside the box, certain garages have been known to s**t themselves when the temp gauge rises, not knowing theres a mason mod on the gauge, "booster" may be what they call it? written on the header so they know not to panic? Especially when sometimes the owners themselves don't know what they've got? Just a thought
They just rang me.. My van is done.
I will ask, then report back!
Seriously...
They got a good rep!
widdowson2008 wrote:Can't you ask the garage what 'booster' signifies? I'd be interested for one.
Perhaps it may mean that the coolant mix has been strenghened by topping up with antifreeze.
No Mason on this P reg loaner Kirsty... But yer right though, they do freak at the Mason reading!
OK, first off it was an R reg...
This brief dalliance with this Younger fresh mint green hussy meant nothing...
I still love my van!!
Back to the mystery of the "boost"..... (Which will probably start a debate all on its own.)
From what i gather, the antifreeze/coolant mixture they use (pink stuff) has an additive that gives it a higher boiling point (If that's possible?) so if it an over heating episode happened "it give you a bit more time to pull over".
I can kind of see a logic in this.. The un-modded gauge don't move until its too late & by that time its boiled & built up too much pressure??? ( I hope thas right?) Well... Unless a leak has occurred, & i guess its cooling on the tarmac.
"boost" just a bit more permanent than a post-it note!
