Help!! Going away Sunday & cig lighter not working..
Lins
Post by Lins » Fri May 13, 2011 7:52 pm
Cigarette lighter not working back and front and we need them for our new fridge, new to all this, so really don't no whether we can sort ourselves or do we need an auto electrician?? Please help!!!??? :( :(
MAZABON
Re: Help!! Going away Sunday & cig lighter not working..
Post by MAZABON » Fri May 13, 2011 7:54 pm
have you checked the fuses ?
mikexgough
Post by mikexgough » Fri May 13, 2011 7:57 pm
Top row..... fuse 8 the last one on the right 15 amp...check that one...
Lins
Post by Lins » Fri May 13, 2011 8:03 pm
Hubby looking right now!! He'snot sure where the fuse box is though?? God we are stupid??!! #-o #-o
haydn callow
Post by haydn callow » Fri May 13, 2011 8:04 pm
They normally only work with the ignition on ?? not much use for a fridge ??
Fusebox by drivers right knee
http://www.coolantalarm.co.uk
Also BMW Clocks
Lins
Post by Lins » Fri May 13, 2011 8:08 pm
Did that!! definitely not working..More of a coolbox to keep the wine chilled whilst on the move!! :lol: :lol:
Post by francophile1947 » Fri May 13, 2011 8:12 pm
Lins wrote:Did that!! definitely not working..More of a coolbox to keep the wine chilled whilst on the move!! :lol: :lol:
Take red wine - no cooling required 8)
haydn callow
Post by haydn callow » Fri May 13, 2011 8:12 pm
front socket or rear ??
Also BMW Clocks
Post by francophile1947 » Fri May 13, 2011 8:15 pm
haydn callow wrote:front socket or rear ??
Both Haydn.
haydn callow
Post by haydn callow » Fri May 13, 2011 9:34 pm
Ah yes.!!
Also BMW Clocks
lazyb5
Post by lazyb5 » Fri May 13, 2011 9:45 pm
Not something as simple as the fuse in the coolbox try something else in the cig lighters to make sure its really them. Then as check fuses Mike says 8 so go with that unless someone has played or you have a conversion. If it is the coolboc fuse its in the part you push into the cig lighter.
Hope we helped.
teenmal
Post by teenmal » Sat May 14, 2011 10:03 am
Hi Lins,
Fuse No8 usually controls Cig lighter/ Mirrors and Radio are they working?
Cheers ..
Lins
Post by Lins » Sun May 22, 2011 4:21 pm
teenmal wrote:Hi Lins,
Cheers ..
Yes they are definitely working, but speaking to the guy where we bought 'bongo' he thinks that someone has used the cig lighter to run electric for something else and may need to take dash off...think we will send her to him!!! #-o
bimbobongo
Post by bimbobongo » Sun May 22, 2011 7:38 pm
I had this when I got my bongo ,the cigar lighter had been disconnected (don't know why )
Plug was dangling under the steering wheel could this be the problem or was it working previously ,have a look under the steering wheel for any loose plugs ,pretty easy to trace to lighter
haydn callow
Post by haydn callow » Sun May 22, 2011 10:20 pm
bimbobongo wrote:I had this when I got my bongo ,the cigar lighter had been disconnected (don't know why )
That wouldn't stop the rear socket from working
Also BMW Clocks
