Rear Suspension bump-stop mounts
Re: Rear Suspension bump-stop mounts
Post by mikeonb4c » Mon May 09, 2011 3:17 pm
bigdaddycain wrote:How much were the bumpstops via Mazda Mike? (onb4c)
Not as cheap as I'd hoped. I phoned Mazda this morning at was quoted £27.39+VAT each. The ebay vendor (autojapspares) has replied saying
HI MIKE WE HAVE GOT A PRICE FOR YOU ON THE BUMP STOPS THEY ?36.14 INCLUDING VAT EACH + ?4.00 POSTAGE FOR THE PAIR IF YOU WANT THESE YOU CAN PAY BY PAYPAL TO ACCOUNT [email protected] OR YOU CAN PHONE THE SHOP AND ORDER OVER THE PHONE THERE WILL BE ABOUT 7 DAYS FROM ORDERING TO BE DELIVERED TO YOU 02476474848
REGARDS
LEE
DISPATCH DEPARTMENT
...but at least we now know they can be got. I might treat myself to one. Maybe they can be got cheaper (if I looked for more suppliers and asked them) but I suspect it wo't be much cheaper.
If I could find a source of hard rubber block, I could be tempted to fashion my own. You could fretsaw and sand the profile, and maybe by heating the baseplate up, it could be used to make the indentation in the base of the rubber block (a smelly operation though I'll warrant :mrgreen: ) 8)
Post by bigdaddycain » Mon May 09, 2011 3:34 pm
I think for my applications, a second hand pair of hollow rubber truck "body buffers" would be quite a bit cheaper... I suppose i could start trawling commercial vehicle dismantlers for a quote on a pair.
And thanks Mike :wink:
Post by mikeonb4c » Mon May 09, 2011 3:49 pm
bigdaddycain wrote:I think for my applications, a second hand pair of hollow rubber truck "body buffers" would be quite a bit cheaper... I suppose i could start trawling commercial vehicle dismantlers for a quote on a pair.
I'd be interested in any idea you come up with. £40 a pop (posted) is a lot for a stupid bit of rubber [-X
teenmal
Post by teenmal » Mon May 09, 2011 3:50 pm
If you dont want to knacker your shock absorbers/dampers,you should not run without bump stops.Doing so could cause the shock absorbers/dampers to bottom out.
Cheers..
Post by mikeonb4c » Mon May 09, 2011 4:49 pm
teenmal wrote:Hi,
Cheers..
I've banged mine once or twice, but I assumed it was the axle banging on the chassis - was I wrong?
nicstrike
Post by nicstrike » Tue May 10, 2011 8:33 pm
bigdaddycain wrote:
nicstrike wrote:
i was a bit wary , hence i doubled up with mechanical fixings too.it was either araldite or gripfill (my usual first choice it has to be said!)
just a thought for a lowered bongo , howsabout polyurathene bumpstops? normally a mod for landrovers etc but could be adapted to suit.
A nice thought, i'd considered it... but ruled out polyurathane as being less compliant (if solid) Now a hollow, yet strong, poly bump stop with no backing plate might do the job. :wink:
there are specific poly bumpstops on the market , so not a case of "making something up".may come in a bit cheaper than standard & should last indefinately. if you wanted to really over-do it you can also get hydraulic bumpstops too.....bit ott on a bongo though , unless someone builds one for comp safari's!!!
