rear heater fan
rev pete
rear heater fan
Post by rev pete » Thu May 05, 2011 12:31 pm
Is it possible to put direct power to my rear heater fan that is not working?. It looks as though the heater fan cannot be removed for repair without removing the whole rear heater unit. My object it to test the fan motor to be certain that nothing else is causing the problem. I can hear the relays etc working and the electrical lincages are functional...Is rear heater removal looking more difficult that it is I wonder? any advice would be most welcome. Thanks.
Re: rear heater fan
Post by g8dhe » Thu May 05, 2011 12:43 pm
You will need to get close to the rear unit but in all models 1995-1999 the the actual Fan motor colours are Blue with Red stripe and Black with Red stripe the relay and resistor are all in the same area as the motor itself.
AlliDelta
Re: rear heater fan
Post by AlliDelta » Thu May 05, 2011 12:48 pm
I can sort you a replacement if you need one out of my breaker. 8)
rev pete
Re: rear heater fan
Post by rev pete » Thu May 05, 2011 2:37 pm
Thanks for your replies. Am i right in that the heater motor cannot be removed without the whole unit? Also is unit removal a major problem? I did wonder if the unit can be moved enough without total removal? [-o<
rev pete
Re: rear heater fan
Post by rev pete » Thu May 05, 2011 2:39 pm
helen&tony
Re: rear heater fan
Post by helen&tony » Thu May 05, 2011 3:09 pm
You can replace the heater motor in the rear without taking the whole unit out.
I replaced mine with no problem
rita
Re: rear heater fan
Post by rita » Thu May 05, 2011 3:39 pm
Hi rev pete,
Have you checked the fuse for the rear heater,there seems to be 2x30amp fuses No 15 for rear and No 17.
Both under the bonnet.
Cheers.
rev pete
Re: rear heater fan
Post by rev pete » Thu May 05, 2011 11:57 pm
I did not realise there are two fuses for the rear heater i will check Thanks
Hi Helen I have tried to get the motor out but I think there must be a spring clip holding the casing together at the rear of the unit but I cannot see only feel the clip I will get a mirror and have another look can you tell me if I am right please.. There is a bolted bracket near the seat runner and two screws on top of the unit...and then what feels like a spring clip halfway down at the back of the fan unit...
Thanks folks
Pete.
rev pete
Re: rear heater fan
Post by rev pete » Fri May 06, 2011 12:06 am
I am losing my marbles I have just found a set of pics from the last time I had trouble i had withis wretched heater There is a bolt uderneath the car by the look of it...Am I correct ???? #-o
Re: rear heater fan
Post by missfixit70 » Fri May 06, 2011 12:10 am
