How to change the thermostat
gazza
Post by gazza » Mon Apr 18, 2011 9:37 pm
I'm sure this has been covered somewhere on the site. But cannot find it.
Is there a fact sheet for changing the thermostat.
I can get the rear most bolt out , but not the front one.
Garry
daveblueozzie
Re: How to change the thermostat
Post by daveblueozzie » Mon Apr 18, 2011 9:50 pm
You undo the bolt holding the dipstick tube, and move it out of the way, that should give you room to get to the other bolt on the thermostat housing.
Lost without my Bongo.
gazza
Post by gazza » Mon Apr 18, 2011 9:52 pm
Thanks for the reply.
So you leave the housing bolted to the engine block?
Do you remove the large coolant hose below it?
Garry
daveblueozzie
Post by daveblueozzie » Mon Apr 18, 2011 9:59 pm
I removed the big hose and all the other hoses connected to the stat, with a bit of fiddling and jiggling, makes it easier to fit the stat, plus i was doing a complete flush and rinse through with a hose and i was fitting a new water pump.
TechnoTurkey
Post by TechnoTurkey » Mon Apr 18, 2011 10:05 pm
I've just done mine and didn't disconnect the pipes, but did move the dipstick tube.
It was easy enough to get the stat out, but would have been easier to get the new one in with the pipes disconnected.
I also swapped the water pump as I spotted it was leaking after swapping the stat - this would be a wise move as it seems like it should be replaced as a service item rather than when you have a problem.
Member 10,000!
1997 Green AFT 4x4 2.5TD Auto Bongo
Post by mikeonb4c » Tue Apr 19, 2011 10:45 am
TechnoTurkey wrote: I also swapped the water pump as I spotted it was leaking after swapping the stat - this would be a wise move as it seems like it should be replaced as a service item rather than when you have a problem.
You make a very good point =D>
I'm guilty as charged :oops:
mikexgough
Post by mikexgough » Tue Apr 19, 2011 1:31 pm
It is what the Japanese recommend and i the main do when they change coolant on a 5yr cycle..... Stat/Pump/Coolant = trouble free motoring.... and for the £38 for a pump....no brainer...while the system is "down"...
