The fact sheet on re-earthing the sender is great, but I'm loathe to just pull up the carpet, as I don't know how to put it back (sounds timid, I know, but I don't want to screw things up). To remove the carpet, do I have to remove any trim first? If so, how easy is it to put back?
Any assistance gratefully received.
Putting back carpet after mending earthing on sender
Re: Putting back carpet after mending earthing on sender
Its quite easy only trim i recall
is a plastic bit hold the end by the gate thats fixes with screws
oh and a blunt not sharp old flat bladed scraper helps to get it back under both sides
- Tribal Elder
When I did mine I borrowed from my wifes haberdashery drawer one of her crochet hooks. With that I was able to pull the plastic off the floor so ast to secure more room for the carpet to slip under.
Ian G
Ian G
Did mine not so long ago and used same method as wonkanoby,not a problem.
- dreamwarrioruk
or if its an earth fault dont bother and just put a link from the chassis to the fuel tank. no messing with the carpet.
mike, jo and emma
Is it as simple as that - just connect anywhere on the tank to the chassis?
Beyond A to B
Thanks to everyone who replied - I'll try earthing the tank first, then take up the carpet if that fails. The less I have to disturb, the happier I am.
- mikexgough
see here several posts to read
