Back vallence rotted out
This might be of interest, being welded up tomorrow
http://i965.photobucket.com/albums/ae13 ... C01538.jpg
http://i965.photobucket.com/albums/ae13 ... C01536.jpg
http://i965.photobucket.com/albums/ae13 ... C01537.jpg
Sparky
Sparky
The Bongo has gone. Long live The Bongo
Hymer Camp Swing 544/Fiat Ducato 2.3jtd
Re: Back vallence rotted out
Ouch!  Presumably you knew it was deteriorating, what with it being in clear view.  I wonder what might be going on with any structural member (if there is one) hidden behind it.
Beneath the floor pan is a box section and it has rotted out on the right angle there is three edges to the metal that the rubber strip grips round, the nuts holding the door catch have sheared off and they go into nutserts it gets worse by the minute
Sparky
									Sparky
Double ouch! Hope you get it sorted OK and that once its done things will settle down. I ought to check mine I think, as DaveBlueOzzie had a similar problem too on an otherwise v. smart Bongosparkymik wrote:Beneath the floor pan is a box section and it has rotted out on the right angle there is three edges to the metal that the rubber strip grips round, the nuts holding the door catch have sheared off and they go into nutserts it gets worse by the minute![]()
Sparky
				dandemann8
If I'm not mistaken I think Daveblueozzie as just had his repaired not long ago
									Bongo no more........... ;-(
				dandemann8
Doh!!!!mikeonb4c wrote:Double ouch! Hope you get it sorted OK and that once its done things will settle down. I ought to check mine I think, as DaveBlueOzzie had a similar problem too on an otherwise v. smart Bongosparkymik wrote:Beneath the floor pan is a box section and it has rotted out on the right angle there is three edges to the metal that the rubber strip grips round, the nuts holding the door catch have sheared off and they go into nutserts it gets worse by the minute![]()
Sparky
				MAZABON
oooh thats nasty
surely this must be caused by a fault with the door seal traping/holding water ?, i must check mine out
- daveblueozzie
Same thing on mine.
http://www.igmaynard.co.uk/bongo/forum/ ... =1&t=46598
Lost without my Bongo.
Wow, what will the repair be - fabricated or a section from a scrapper?
Even mine has started to let go!
  And my bongo doesn't get used in the winter time
Thankfully it's the only rust on mine, it was right on the lip of the leading edge where the two panels are pressed together. It came off with a few passes with a wire brush, i injected waxoyl into the seam, and into the weather strip seal then re-fitted the weather strip to lock in the waxoyl so it could do it's thing. Everybody should check the state of theirs, takes two seconds to check.
Simply open the tailgate, pull the weatherstrip straight towards you off the body (my surface rust was almost level with the tailgate striker plate).
DBO's had the rot cut away, then a fresh sheet of steel welded on, then stonechip guarded, then painted, waxoyled on the inside.dobby wrote:Wow, what will the repair be - fabricated or a section from a scrapper?
Ta, timely warning to us all this one I think
Worth whipping the weather strip off a bit to have a look Graham, takes less than a minute to check
Bongo's back from Mr T's at the weekend, next job on the list.
And a sharp intake of breath when revealed!!bigdaddycain wrote: takes less than a minute to check
