Not sure without splitting the pump exactly where it goes. (Don't want to split this pump cos I have plans for itg8dhe wrote:Does it lead into the bearing bore? Perhaps its between the packing washer and the support bearing to allow any water that gets past the packing washer to exit before it gets into the actual support bearing and causes problems ?
Guessing here. Just behind the impellor, in the casing, there will be a rotary seal. For coolant to get past this seal suggests the seal is buggered.
Once past the seal, coolant is straight into the bearing, but the bearing is solid (not a ball race or needle) so what damage could it cause? and doesn't antifreeze have lubricating properties anyway? (thought I had read that somewhere)
Also, if your assumption is correct (not saying it isn't), then what is the top hole for?
