My First Bongo
AidanandDonna
My First Bongo
Post by AidanandDonna » Sat Mar 12, 2011 5:40 pm
Hello All,
The missus and I have recently purchased our first Bongo, there are few things on it that don’t work, before I take it to a auto electrician wondered if any of you guys could enlighten me.
There are parking sensors on each corner of the car and a button on the dash, vie had a fiddle and tried to follow to cable but I don’t even know where it should end up.
Also there is a toggle switch on the dash which doesn’t appear to do anything
And finally there are some spot lights on the bull bar, I am a complete novice when it comes to cars, but I will give anything a go, will it be easy to wire these up, here is a picture of the connecter
Thanks in advance
Aidan
Re: My First Bongo
Post by g8dhe » Sat Mar 12, 2011 6:03 pm
Welcome to the forum!
Regarding the corner sensors there should be a display on the top of the dashboard roughly central but angled towards the driver that shows the distance and also one in the rear visible via the mirror that shows the distance when in reverse. Only three corners (not the drivers corner) and the rear are covered.
AidanandDonna
Re: My First Bongo
Post by AidanandDonna » Sat Mar 12, 2011 6:20 pm
Hello, Thanks for the quick reply
Unfortunately there is no display on the dash, doesn't look like anything has been removed
Here is a pic of the corner sensors
kawasaki kid
Re: My First Bongo
Post by kawasaki kid » Sat Mar 12, 2011 6:54 pm
Hi, do you have a little black round rocker switch about 3 inches below the row of switches by the cigarette lighter / drivers left knee - thats where my sensors are operated from - they can be turned off and on. :)
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
AidanandDonna
Re: My First Bongo
Post by AidanandDonna » Sat Mar 12, 2011 7:07 pm
kawasaki kid wrote:Hi, do you have a little black round rocker switch about 3 inches below the row of switches by the cigarette lighter / drivers left knee - thats where my sensors are operated from - they can be turned off and on. :)
Thank you! just went and tried it, works great :D the missus will be well chuffed with that, she is still struggling with the parking a bit.
Cosmic Bus
Re: My First Bongo
Post by Cosmic Bus » Sat Mar 12, 2011 8:39 pm
I notice two things here. One, it says sound - on/off, so does it beep faster the closer you are?
Two, that's really close to the kerb parking there :lol:
Wish I'd had that bit of kit though before I bounced the back bumper off of some fallen down wall :roll:
AidanandDonna
Re: My First Bongo
Post by AidanandDonna » Sat Mar 12, 2011 9:07 pm
Just went for a run down to the shops and thought i'd test out the sensors, but turns out the back two sensors aren't working :( they just keep flashing, but front two work great, will take a look tomorrow and see if theres a loose connection or something.
Cosmic Bus wrote:I notice two things here. One, it says sound - on/off, so does it beep faster the closer you are?
But yeh it does beep faster the closer you are, its a shame the back two dont work becasue i've already had a couple of close calls
kawasaki kid
Re: My First Bongo
Post by kawasaki kid » Sat Mar 12, 2011 10:20 pm
You will find some block connectors behind the rear bumper as a starting point. :)
waycar8
Re: My First Bongo
Post by waycar8 » Sun Mar 13, 2011 1:29 pm
The toggle switch may well be the rear fog light :wink:
