Post
by jed1y0da » Sat Apr 02, 2011 3:20 pm
UPDATE 4: ok - finally took it to Discount trucks (great bunch by-the-way) and they had it for 3 weeks (did a complete major service and a few other bits and pieces). The air in the system was caused by fractured fuel lines (the metal ones that go into the injectors) - apparently 90% of fuel related probs discount trucks rectify on bongo's are the cracking of these fuel lines. Its a hard one to check for, but my symptoms (leave it for 1-2 hrs then try to start it and it will fire for about 3secs then die, then turning it over for about 1 min and it will start to fire and then run real lumpy for 20secs or so and then be fine) are endemic of this particular problem.
Oh yeah - also had a slightly leaking O ring , but that wouldn't cause air to get in the system unless it was completely gone.
Hope that helps : )
