Got to love cars!!
The Bongo has been in the garage for nearly 6 months and is still exhibiting the same symptoms and the garage is running/has run out of options. The ECU, Fuel ECU, Engine Temperature Sender Unit, Lamda Sensor, Dizzy Cap, HT Leads, Plugs, Rotor Arm, Coil, Intake manifold, Fuel Pump, AIr intake valve have all been either checked or replaced. The Fuel tank has been drained and the fuel filters have been checked. I think some other things have been done but I have lost track.
It's looking like I'll have to take it back and either take it somewhere else or work through things, whatever things??, myself.
Does anyone have any inventive ideas to check for to cure this problem as I want my baby back!!
The symptoms are still the same. It runs fine from cold and then after the cooling fan has cut in and out about 3 times it starts to jerk/misfire/over fuel severely to make it undriveable. It used to be that if you could use road speed to get the engine revs over 2000rpm that it would drive fine but this hasn't been chekced recently as it's been running in the garage, stationary.
Due to its specific link to engine revs and heat of engine you'd expect it to be sensor related but they appear to have all been checked. Are there any extra ones?
Anyway, any suggestions, however odd are probably worth considering.
