Tyre aspects ?
droodle
Tyre aspects ?
Post by droodle » Mon Mar 07, 2011 1:13 pm
Hello ..
I need 2 new front tyres - currently my tyres are 195/70 r15 97T front and back 215/65 R15 100T, reading here ive heard the accelera tyres are a good budget recommendation but they don't do these exact sizes, so would it matter if the aspect changed slightly to say 195/65 or 55 ??
Also to add currently on the speedo i get 80 on the dash and just over 70 on the sat nav is this what effects it ?
cheers.
Re: Tyre aspects ?
Post by francophile1947 » Mon Mar 07, 2011 1:18 pm
If yours is 2WD it won't matter, but it could wreck the viscous coupling on a 4WD.
Just put 215/65 all round - loads of people have 8)
droodle
Re: Tyre aspects ?
Post by droodle » Mon Mar 07, 2011 1:27 pm
cheers .. yep its 2WD
mikexgough
Re: Tyre aspects ?
Post by mikexgough » Mon Mar 07, 2011 2:55 pm
droodle wrote:Hello ..
cheers.
quick visit from me............ Accelera Tyres here the correct size £49 each hope it helps
wishmaster
Re: Tyre aspects ?
Post by wishmaster » Mon Mar 07, 2011 7:05 pm
Go 215/65 all round, we have @ £40 a corner :wink:
I have a plan and its as HOT as my pants
IZZY
http://s633.photobucket.com/albums/uu57/izzy2619/
David Edwards
Re: Tyre aspects ?
Post by David Edwards » Mon Mar 07, 2011 7:12 pm
Yep same for me for the last eight years 215's all round, acceleras £38.00 each fully fitted, good tyres too, have used others tho.
LoopyLoo
Re: Tyre aspects ?
Post by LoopyLoo » Mon Mar 07, 2011 11:26 pm
I need new tyres all around on mine, its still got japanese tyres on , the treads are ok but they're all cracked round the edges which is a bit :shock: only noticed the other day when I put air in.
But being not particularly 'up' on this sort of thing I don't know what size is on there, or what size to buy. Whereas my other cars have got the sizes/numbers written on the tyres these don't seem to?
If I take it to a tyre place will they know? Plus I have no idea if I have different ones on the back than the front etc..
any help appreciated!!
dext924
Re: Tyre aspects ?
Post by dext924 » Mon Mar 07, 2011 11:59 pm
droodle wrote: Also to add currently on the speedo i get 80 on the dash and just over 70 on the sat nav is this what effects it ?
I have this as well, speedo says 55 and actually only doing 50! not sure what causes this as it has done it since buying it straight from import. I was wondering if the right MPH dial had been fitted??
Re: Tyre aspects ?
Post by francophile1947 » Tue Mar 08, 2011 12:57 pm
Speedos almost always over-read #-o Just fit bigger tyres when next needed 8)
Bongoing
Re: Tyre aspects ?
Post by Bongoing » Tue Mar 08, 2011 9:29 pm
I also am unsure what to do! I need 2 new tyres for my 2wd Freda (side conversion). Currently have 215/60 16 on the rear and 205/60 16 on the front. Need 1 new back tyre and 1 new front tyre. After reading various posts think I am going to replace all four with 215/60 16. This seems to be what most people advise is this correct? Therefore when done will have one good used 215/60 16 tyre left. Can I put this on a 16" steel and use as a spare, if yes where can i get a steel wheel that fits and from what vehicle and will it still fit underneath like the current skinny spare. Any advice appreciated.
Many thanks
Re: Tyre aspects ?
Post by francophile1947 » Wed Mar 09, 2011 1:06 pm
215/60x16s are fine. A spare with those tyres will fit underneath, but I haven't got a clue which 16" wheel you need to buy :oops: Just make sure it has 5 stud holes, a PCD of 114.3mm and a centre bore of 67.1mm.
This site will let you see which wheels have the right PCD etc (mainly Mazda, Hyundai and Kia), but it doesn't show the wheel sizes http://www.alloywheelsinternational.com ... UIDE1.html
Bongoing
Re: Tyre aspects ?
Post by Bongoing » Wed Mar 09, 2011 11:32 pm
Thanks for the reply,have now decided on 215/60 16 all round and will keep my eyes open for a suitable 16" steel to use as a spare.
Bongoing
Re: Tyre aspects ?
Post by Bongoing » Wed Mar 16, 2011 10:55 pm
Have just had a full set of 215/60 R16 99w XL Marangoni Verso tyres fitted at £66.00 a tyre. Seemed a decent trade of between cost and quality as they are meant to be a mid range tyre as opposed to a budget tyre. I am now trying to find a suitable 16" steel to put the decent old tyre on as a spare and this is proving more difficult. So if anyone knows what particular 16" steel will fit any help would be appreciated.
