fuel pump seals
kpautos
fuel pump seals
Post by kpautos » Tue Jan 25, 2011 5:27 pm
i know its all been on here before but i have the following issue, i replaced the fuel pump seals and now the vehicle wont start, not 100% that i put the internals in the right way, have tried different ways, no derv output from pump, self bleed type, there is mention of a pdf of the internals of the pump, where can i find it?, vehicle ran ok before apart from diesel leak, at end of tether! customer being very patient[but is not well] so could do with a result, any help would be great, regards, kirk.
sorry 1995 bongo.
rita
Re: fuel pump seals
Post by rita » Tue Jan 25, 2011 5:32 pm
Hi kpautos,
Try filling the fuel filter with diesel,sometimes they dont self bleed.
Cheers.
kpautos
Re: fuel pump seals
Post by kpautos » Tue Jan 25, 2011 5:46 pm
fuel filter is full, pump not pulling through, unsure that i have re-assembled correctly
rita
Re: fuel pump seals
Post by rita » Tue Jan 25, 2011 6:15 pm
kpautos wrote:fuel filter is full, pump not pulling through, unsure that i have re-assembled correctly
PM sent...
kpautos
Re: fuel pump seals
Post by kpautos » Tue Jan 25, 2011 6:54 pm
thanks, but the pics are not in enough detail for me to see parts close enough, its frustrating!
rita
Re: fuel pump seals
Post by rita » Wed Jan 26, 2011 12:13 pm
hi,you could check this out, maybe PM bongobum82 or cosmic bus..
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=45939
kpautos
Re: fuel pump seals
Post by kpautos » Wed Jan 26, 2011 7:09 pm
thanks for your help, not enough detail in these pics though, regards, kirk
gazza
Re: fuel pump seals
Post by gazza » Sat Jan 29, 2011 6:58 pm
I had the same problem. See my post called - Diesel pump seals
The way I got mine running in the end was to take off the inlet pipe to the pump , put a funnel on the end of the pipe and fill with diesel. The engine should then start and run until the diesel is used up, the pump is now primed.
Put the inlet pipe back on and it will run.
Hope this helps
Garry
kpautos
Re: fuel pump seals
Post by kpautos » Mon Jan 31, 2011 2:56 pm
ok success at last..... used my vac pump to draw derv through pump return system, started almost instantly, have had running for 15 minutes, revs fine, no leaks, cannot try performance on road as its trapped at the rear of the workshop till i clear other work, heres hoping!
kpautos
Re: fuel pump seals
Post by kpautos » Tue Feb 01, 2011 6:43 pm
UPDATE!
vehicle now starts and runs fine, no smoke, performance as it should be, thanks to all who helped me through including the very nice man at lawson diesels who supplied the seals!
next problems are 1, no speedo and 2, fuel gauge inop, will start searching for these now!
lazyb5
Re: fuel pump seals
Post by lazyb5 » Tue Feb 01, 2011 7:22 pm
Hi ,
Not sure about the speedo but the fuel gauge is probably a duff earth through the tank.
Re: fuel pump seals
Post by francophile1947 » Tue Feb 01, 2011 7:35 pm
Speedo is often a faulty conversion chip. Does the mileage read in miles or Kms?
kpautos
Re: fuel pump seals
Post by kpautos » Tue Feb 01, 2011 8:54 pm
Will check tommorow about mph/km, found usefull info about earth etc on the fury site so will investigate asap, thanks, kirk.
kpautos
Re: fuel pump seals
Post by kpautos » Tue Feb 08, 2011 4:39 pm
the speedo is in mph so i guess its been converted, was out test driving it after fitting new belts and pressed the re-set on the mileometer and presto the speedo jumped into life, it lasted the rest of that journey and then resorted back to u/s, customer informed me that it would allways work if tapped lightly for a while, now its u/s all the time, any ideas?----sounds like the actual dash part to me-where is the conversion chip located?, thanks in advance, kirk.
Re: fuel pump seals
Post by francophile1947 » Tue Feb 08, 2011 4:58 pm
kpautos wrote:the speedo is in mph so i guess its been converted,
Speedo will read in MPH, no matter how it's been changed. If the speedo face goes up to 110mph, it's probably a new face fitted over the old one. If it goes way over 110mph, the speedo has been chipped - that chip often causes speedo problems. Another way to check how it's been converted is shown in my earlier post - does odometer read in miles or kms? If it's miles, it's chipped. Ones with a new face still measure mileage in kms.
