hi has anyone got a broken bongo window switch (drivers side)?
I got a replacement for mine but one of the brass retaining things is snaped off , so i need just the top cover (surround)of the switch the part that locks into the door card hole with a clip at each end,
thanks in advance
steven
broken window switch?
steve alan
Re: broken switch?
its been mentioned on here before but you can simple remove the front screw and put a small piece of spring steel with a dog leg in it, so that it hooks under the front of the door card.
sorted.
sorted.
Re: broken window switch?
Follow this thread, save cash... http://www.igmaynard.co.uk/bongo/forum/ ... witch+clip
