Brand New Fuel Filter Failure Problem.....
BeArDy
Post by BeArDy » Thu Jan 27, 2011 10:54 pm
Just seeing if anyone else has had this problem.
Driving along in my 2.5TD an all of a sudden lost power, she would not rev over 2000rpm.
Bongo was given a full service 3 day prev's.
Found the problem to be a lack of fuel to the engine.
After alot of searching/fault finding i found the problem to be the fuel filter.
Inside the fuel filter there is a spring system which works with pressure and on the new patten part the spring system had jammed.
Replaced with old filter and she ran perfect, problem solved......
Anyone know is this a problem common? what fuel filters to people use? genuine part only?
wonkanoby
Re: Brand New Fuel Filter Failure Problem.....
Post by wonkanoby » Fri Jan 28, 2011 11:49 am
were did yours come from
Post by francophile1947 » Fri Jan 28, 2011 1:13 pm
BeArDy wrote:Anyone know is this a problem common? what fuel filters to people use? genuine part only?
Common problem - No :D
Type of filter - whatever I can get, but usually ones from the club shop 8)
gmaczbongo
Post by gmaczbongo » Fri Jan 28, 2011 3:12 pm
Never heard of that before.
Ebay cheapos.
teenmal
Post by teenmal » Fri Jan 28, 2011 3:30 pm
Hi BeArDy,
Do you have the maker and part number of the filter,or a pic of the spring arrangement.
Cheers Mal..
chipvan
Post by chipvan » Fri Jan 28, 2011 8:06 pm
have had ones off ebay.but one was rubbish.fell to bits. :cry:
next one from club for me =D>
