Hello Folks
Small problem, wonder if anyone can help?
We have an S reg 2.5 V6 petrol bongo. Under most conditions it starts first time no problem. However, if the weather is damp, drizzly and windy (Quite frequent here in north Cornwall), it can be very difficult to start, turning over for 6 to 10 seconds before firing! I'm pretty sure the HT leads must getting damp and causing a loss of spark. This morning, after several days standing in this weather, she wouldn't start at all!
Has anyone experienced similar problems?
Steve
Poor starting V6
bolo
Re: Poor starting V6
Try a damp spray on the leads, distributor cap etc.
If you lift the seat, can you see any sparking?
Re: Poor starting
Try removing the distributor cap and rotor arm clean down and give a a blast of something like duck oil of wd40 wipe excess off with a cloth and do the same with ht leads
works well for most
If persist change the said parts
hope this helps Cheers Steve.
works well for most
I am the only bongo in the village.......(not anymore there's two of us now "Damn it)
Beat me to it again John
bolo
Thanks guys,
Didn't notice any sparking but I'll look a little closer. I've tried spraying the leads etc but not removing the distributor cap. I'll give that a go tomorrow.
Steve
PS: Apologies for not including V6 in the original title.
Steve
- haydn callow
I would replace the dizzy cap and rota arm...clean all the plug leads and fit new plugs.....don't forget to clean up the 7th "coil" lead....
I suppose first it would be a idea to check your battery is producing enough amps
Also remove the disty cap and check the carbon finger that touches the top of the rotor arm, these can wear down over time and result in a weaker spark.
Andy
Andy
New Forest Terrier
I had exactly the same problem with my V6 last year. First time starter unless it rained. Then start walking
It took quite some time to find the problem. Every time it got looked at, the beast started of course.
My problem was just as apole mentioned, the carbon finger inside the dizzy cap had worn away. With a strong spark it was still managing fine in dry conditions. A new dizzy cap cured the problem completely. I added new spark plugs as well and never a poor start since
The BewilderBeast - V6 Mean Green Tintop with LPG and 321 Away Montague Conversion
