V6 Engine oil
- haydn callow
V6 Engine oil
I am changing the engine oil/filter in the V6......how does 15/40 semi synthetic sound ??
Re: V6 Engine oil
Worth a look regards cats...http://www.tmsmotorspares.co.uk/magazin ... which.htmlhaydn callow wrote:I am changing the engine oil/filter in the V6......how does 15/40 semi synthetic sound ??
Cheers.
Re: V6 Engine oil
It's what loads of garages use for everything - Shell being the most common (must be the trade's cheapesthaydn callow wrote:I am changing the engine oil/filter in the V6......how does 15/40 semi synthetic sound ??
Re: V6 Engine oil
Hi Haydn,
good quality semi synth 15-40 works fine in mine. Tried other oils such as 5w30 etc and car much smoother on the 15-40.
Andy
Andy
- haydn callow
Re: V6 Engine oil
15/40 Semi Syn it is then
thanks
thanks
David Edwards
Re: V6 Engine oil
Asda had an offer on..or at least ours does, castrol £10.00 instead of twenty something
maviczap
Re: V6 Engine oil
Halfrauds 10/40 is £16.99 for 5 litres at the mo, just bought some diesl semi synh at £17.99
Re: V6 Engine oil
haydn,to me 15w seems too thick for the cold starts, it may not get to get to the top of the engine fast enough for that initial protection, especially in winter. the 40 seems fine for the hot top end temps.
please contact millers oils at brighouse yorkshire,they are on the net,they have a tecky/advice dept, tell them what you have,including the gas mod, and cat if it still has it, and they will give you great advice.
you have a real nice motor that may have special needs(gas) dont risk the wrong stuff.
if you decide to buy one of their oils give me a shout(i know a man).ssshhhh.
wishmaster
- Tribal Elder
Re: V6 Engine oil
We use 10/40 semi in our V6 and it purrs
as Dave Edwards says on offer in Asda, 4ltr for £10 at the moment
- haydn callow
Re: V6 Engine oil
Thanks Ady
lpgimports
Re: V6 Engine oil
I use 10/40 semi in diesels and high mileage ones.
5/30 semi in V6 ones
Paul
Paul
http://WWW.NEWACRECARS.COM IMPORTERS
