Running cold V6
splash2
Running cold V6
Post by splash2 » Wed Dec 22, 2010 11:55 am
Hi All,
I drove my Bongo from Gloucester to Bristol this morning, about 40 miles. The temperature gauge never moved - should I be worried?
A.
Re: Running cold
Post by Ian » Wed Dec 22, 2010 12:31 pm
Your thermostat is probably jammed open. It shouldn't cause any short term harm, but I'd get it sorted sooner rather than later.
haydn callow
Re: Running cold
Post by haydn callow » Wed Dec 22, 2010 12:34 pm
Could well be the above or a fault in the sensor/wire/gauge.......my V6 runs cool but the gauge moves up tp normal in a couple of miles.
http://www.coolantalarm.co.uk
Also BMW Clocks
Re: Running cold
Post by mikeonb4c » Wed Dec 22, 2010 1:20 pm
Ian wrote:Your thermostat is probably jammed open.
Or else it hasn't got one - it has been known. Out of interest, does the gauge normally move to the 11.00 o'clock position then stay in that position all the time? Or has it been known to drift down a bit at times, especially when you are on the move?
haydn callow
Re: Running cold V6
Post by haydn callow » Wed Dec 22, 2010 1:52 pm
Mike.....I think we can assume that things have been normal up to this trip....implication of that being a Stat is fitted.
Are the heaters working as normal ?? if so it points to a fault in the gauge circuit.....if not then a stuck Stat
Also BMW Clocks
Re: Running cold V6
Post by missfixit70 » Wed Dec 22, 2010 1:52 pm
Did your heaters get hot?
haydn callow
Re: Running cold V6
Post by haydn callow » Wed Dec 22, 2010 1:53 pm
Kirsty......beat you....that's a first....you must have dozed off!!
Also BMW Clocks
Re: Running cold V6
Post by mikeonb4c » Wed Dec 22, 2010 1:56 pm
haydn callow wrote:Mike.....I think we can assume that things have been normal up to this trip....implication of that being a Stat is fitted.
As an ex-Army bloke Haydn, you'll know the danger of assuming things :wink:
Better considered unneccessarily than overlooked unfortunately 8)
Re: Running cold V6
Post by missfixit70 » Wed Dec 22, 2010 2:25 pm
haydn callow wrote:Kirsty......beat you....that's a first....you must have dozed off!!
I'm getting old now :wink:
haydn callow
Re: Running cold V6
Post by haydn callow » Wed Dec 22, 2010 2:36 pm
at least we are thinking along the same lines and asking the same ???'s
Also BMW Clocks
Re: Running cold V6
Post by mikeonb4c » Wed Dec 22, 2010 2:41 pm
haydn callow wrote:at least we are thinking along the same lines and asking the same ???'s
:lol: :lol: :lol:
As an ex-army mate of mine once said to me "If all elses fails.....duck!"
Have a good Crimbo 8)
splash2
Re: Running cold
Post by splash2 » Wed Dec 22, 2010 4:06 pm
Thank you all for your replies. Re the above: The gauge normally sits at 11 o'clock and never moves. There's not much heat coming from either heater.
Re: Running cold V6
Post by bigdaddycain » Wed Dec 22, 2010 4:15 pm
Have you checked the coolant level Splash2?
Re: Running cold
Post by mikeonb4c » Wed Dec 22, 2010 4:18 pm
Hmmmm. Don't much like the sound of that. Have you checked your coolant level? If its low it isn't sufficient just to top it up as if air has got into the system meanwhile, it will need bleeding out. You shouldn't drive it until this has been been done as there's a risk of damaging the engine (although its the diesel that is well known to be damaged in this situation - not so much reported about the V6 or 2.0l petrol engines).
See if the techies agree with the above 8)
PS - Bigdaddy already has (beaten me tuit :lol: )
splash2
Re: Running cold V6
Post by splash2 » Thu Dec 23, 2010 9:38 am
Yes - coolant level is right up to the top so I guess I need to investigate the state of the thermostat.
