Ignition Key Light help please.
Triple/R
Post by Triple/R » Wed Nov 24, 2010 2:28 pm
Eyup everyone :) ~hopefully you will be able to help :)
The missus is struggling a bit (dark nights) to find the ignition (to put key in) as unlike some motors the ignition dosen't light up.
There is a small hole (pushout piece of plastic) to the left of the keyhole~i'm struggling to find anything (bulb holder & bulb) suitable as it's a bit restricted inside cowling~has anyone fitted a light next to ignition keyhole?? if so could you tell me please where i can get one from
Any help appreciated :)
Regards Ray & Christine
flossie
Re: Ignition Key Light help please.
Post by flossie » Wed Nov 24, 2010 3:03 pm
I've got a light there in fact my Dad commented how useful ... What about a light on her key fob instead - probably cheaper and easier ?
Liz
'99 V6 White over Silver - as yet unconverted but I may be converted!
Triple/R
Post by Triple/R » Wed Nov 24, 2010 3:06 pm
flossie wrote:I've got a light there in fact my Dad commented how useful ... What about a light on her key fob instead - probably cheaper and easier ?
Yes Liz~~that's probably the sensible answer,well worth considering :)
Post by g8dhe » Wed Nov 24, 2010 3:18 pm
Has some one cannibalised the sound warning system (beeper) as the lamp should be powered from the same module;
Triple/R
Post by Triple/R » Wed Nov 24, 2010 3:25 pm
g8dhe wrote:Has some one cannibalised the sound warning system (beeper) as the lamp should be powered from the same module;
Sorry Geoff~don't understand :oops: what lamp~ someone has stopped the bleeper system except for reversing bleeper~~as for cannibalise if your refering to small hole on left of ign key,i just pressed it out.
Post by g8dhe » Wed Nov 24, 2010 5:13 pm
There should be a lamp behind it, the circuit appears as below in the wiring manual for 1997-1999, so hence I wondered if any one had perhaps stripped out the warning bleeper box and maybe more ... hold on maybe your 1995-1997 in which case they don't appear to have the lamp installed, perhaps that's the case ?
Triple/R
Post by Triple/R » Wed Nov 24, 2010 5:18 pm
g8dhe wrote:There should be a lamp behind it, the circuit appears as below in the wiring manual for 1997-1999, so hence I wondered if any one had perhaps stripped out the warning bleeper box and maybe more ... hold on maybe your 1995-1997 in which case they don't appear to have the lamp installed, perhaps that's the case ?
Yes mine is a 97P~theres no sign of anything being there before~as i said i actually pushed the plastic bit out with my finger so there was'nt anything there before~but thanks anyway :)
Post by Muzorewa » Wed Nov 24, 2010 5:52 pm
I think only the later ones had a light there, ours is 98 S and has a light fitted :wink:
Jaws
Post by Jaws » Wed Nov 24, 2010 6:38 pm
Muzorewa wrote:I think only the later ones had a light there, ours is 98 S and has a light fitted :wink:
Definitely a geen light on our 98 model: often thought how useful it is!
Perhaps you could rig up an LED running off the interior light circuit/door switch?
Live Bongo and prosper.
Triple/R
Post by Triple/R » Wed Nov 24, 2010 7:38 pm
Yes thanks~ the problem isn't rigging one up,but don't know where to buy bulb & holder from & theres not a lot of room behind the cowling~~was wondering how big (at the back) the light is on the more modern Bongo eg 98/99 models cus the dash & steering wheel cowling looks the same to me as my 97 model.
rita
Post by rita » Wed Nov 24, 2010 7:59 pm
Hi,this might help.....http://www.lushprojects.com/bongopartsm ... mgno=.html
Cheers..
Jaws
Post by Jaws » Wed Nov 24, 2010 8:21 pm
OK. Sorry, I haven't yet had occasion to dismantle the cowling to check this out. I was thinking more along the lines of a small LED i.e low power, small device requiring only small gauge wiring to refelct the likely lack of room.
May be like this sort of thing? http://www.ultraleds.co.uk/u286b-dash-b ... p-851.html
Hope that helps
mister munkey
Post by mister munkey » Wed Nov 24, 2010 8:29 pm
The light on the barrel was only fitted to 98> Bongos, along with a dash gear indicator panel, not sure you could retrofit one Ray.
Flossies' idea sound a lot more straightforward.
:D
jaylee
Post by jaylee » Wed Nov 24, 2010 8:37 pm
I fitted one!
Using one of these i had lying about spare.... http://www.nrebate.com/en/high-powered- ... rrency=GBP
Just drilled a tidy hole in the existing cover/cap & pushed the bulb through. Tells me if my lights on too when i remove the key, in silent beep mode... :oops: (sounds a bit silly, Daylight easy to spot.)
Handy indeed!
Triple/R
Post by Triple/R » Wed Nov 24, 2010 9:43 pm
Thanks everyone for your ideas,very helpful so far =D> & thanks for the link's.
Yes Chris Flossies idea is defo the easy route~i'll see how i go.
