colour codes for wiring to electric windows
steve alan
started to sort the wire's out today (cold & wet) managed to get the central locking working (break in wire where it bends in door clip) anybody got the colour codes of the wires for the elec windows got to sort them next cannot see any breaks so its down to testing them also which fuse for windows?, will also have to test the switches up top ,any ideas as to what to look for (to see if switch is faulty drivers side)
thanks
steve
thanks
steve
Re: colour codes for wiring to electric windows
jaylee or geoff are your chaps for the colours,but the switch is fairly straight forward.BEWARE OF THE FLYING BALLBEARING AND SMALL SPRING.usually the switch pivots wear or break,then its just clean all the contacts.
steve alan
cheers ady
well have pulled the switch apart , seem's there is a small nylon peg snaped off on the unit (blue top) so thinking that's the problem,
jaylee is on now and can feel him typing now
steve alan
well just put striped down switch back on moved broken side up & down can hear and feel something clicking on board so seem's like power's there, but window still not moving up or down so now at a loss as what to look for?
steve
steve
What are the window symptoms..? Do you get a buzz with window inoperative behavior?
steve alan
not that I know of , when plug switch in get a buz like feeling whilst holding the switch when I move the slider with screwdriver Back & forth can feel and hear a click (think its comming from the black box on the switch
Is it just the drivers window playing up?
steve alan
yes passenger window works fine (from passenger switch only) not from drivers side
going to a breakers in wigan tommorow so gonna take switch and see if hes got a bongo with working swich,will see if I can try this one on it , if it dont work guess switch is goosed
I'm thinking the pots on the switch could be shot...!!?
Ave a look at this.. Could turn out to be a cheaper solution than a hundred odd for an original...?? http://www.igmaynard.co.uk/bongo/forum/ ... dow+switch
steve alan
well just checked the circut board and found a broken track so have solderd a wire across it,have fixed the broken pin by heating a paper clip up melting a hole tho nylon and then used an eye (from curtain wire) to tap a thred and screw it in just need to cut eye off the thing and should be ok,and work the slider,did look at the post you sugested what typ/year was the 626 switch you modded was it one with the 4 door switches ?
steve
steve
Make sure the door loom wires have no cracks where they bend before replacing the switch & turning on the ignition to test.. There may have been a short in the loom to cause the PCB to fry on your switch in that spot??steve alan wrote:well just checked the circut board and found a broken track so have solderd a wire across it,have fixed the broken pin by heating a paper clip up melting a hole tho nylon and then used an eye (from curtain wire) to tap a thred and screw it in just need to cut eye off the thing and should be ok,and work the slider,did look at the post you sugested what typ/year was the 626 switch you modded was it one with the 4 door switches ?
steve
Mid 90's two door version.. The plate was different, but the original Bongo plate fitted the switch box... The rocker switch was wired up differently to push out 12v as opposed to the original which stops the passenger window operation through the driver switch. I used the 626 rocker to act as a panic button on my alarm, locking the vehicle & closing any opened windows on the cab!
I also fitted a closure module to fold the mirrors on locking.. They open when starting the vehicle.. http://www.igmaynard.co.uk/bongo/forum/ ... lit=mirror
& yes i did fry the PCB on the mirror switch in the experiment..
Ohh sounds like a series of problems, anyway the colours you need are here, click the thumbnail below that's the diagram then click the little
to get the colour code page up, then its just a case of reading the letters inside the wire and converting to colours;
This may help too.. http://www.igmaynard.co.uk/bongo/forum/ ... +door+loom
steve alan
Paid wheelQuick a visit today picked up some missing bits & tested the switch there totaly dead,so will have to get another or mod one not waistin any more time on it,
thanks
steve
thanks
steve
