after bumps /hard braking oil light and slight ticking noise
kickinthebongos
Post by kickinthebongos » Tue Oct 05, 2010 10:12 pm
when i do an emergency stop or go over a big bump the oil light comes on and a strange soft ticking noise happens. in variably when i switch the engine off and back on the oil light goes off.
i had the oil switch replaced but problem still there
dandywarhol
Re: after bumps /hard braking oil light and slight ticking noise
Post by dandywarhol » Tue Oct 05, 2010 10:59 pm
Check the oil level? :?
kickinthebongos
Post by kickinthebongos » Tue Oct 05, 2010 11:59 pm
oil level fine
jaylee
Post by jaylee » Wed Oct 06, 2010 12:07 am
Just a thought... Any other inconsistencies with the dial pod read out when this happens..?
Tripewriter
Post by Tripewriter » Wed Oct 06, 2010 9:06 am
Put another litre of oil in.
haydn callow
Post by haydn callow » Wed Oct 06, 2010 10:02 am
Just a thought....you are checking the engine oil and not the Auto box level.....????
http://www.coolantalarm.co.uk
Also BMW Clocks
gmaczbongo
Post by gmaczbongo » Wed Oct 06, 2010 8:50 pm
Are you looking at the right warning light.
Not sure about the bongo, heavy braking and lowish fluid will have the brake warning light flashing.
