I'm removing my cylinder head to get it tested for cracks/distortion. Is it necessary to remove the camshaft to do this or can I leave it in place? As a non-mechanic I want to leave as much as is as possible.
Ta...Rob
Cylinder head removal - do I take off camshaft?
That sounds about right so you now have to make the decision:
1. take a chance that all is well and leave the cam in place but accept that you will have to have it returned to remove cam and send back for machining, incurring cost and time
2. play it safe by removing cam now and all you lose is your time to remove the cam and replace after head comes back.
yes i agree.the camshaft can also be inspected for wear at the same time,we,ve just done a complete engine restoration and completely stripped our unit to a bare shell,also check for sludge in the water jacket that surrounds the engine,if this gets blocked it can cause major overheating problems.paul
Thanks guys....ok, I'm TRYING to remove my camshaft! I just can't shift the nut on the cam pulley wheel! I've got a meaty 26mm wrench on the camshaft and the longest 17mm ring I can find on the pulley wheel but the nut will not budge. I assume it's a normal thread direction?
Any hints or tricks I can use?
Cheers ......Rob
As a non mechanic, ripping apart my Bongo is a very interesting and satisfying journey to tske. But I'm seriously going to whoop it up on this forum if I can get back together again and it runs and it doesn't overheat!
Cheers ......Rob
The nut doesn't appear to have anything like 'Loctite' on it per chance? Try a good hefty whack to the spanner with a mallet to 'shock' it loose.
With regard to your overheating fears. Check the coolant pathways in the head for blockages as they can be narrow in places and accumulate sedimentation thus restricting coolant flow.
