Leaking radiator
lars
Leaking radiator
Post by lars » Fri Aug 13, 2010 2:28 pm
Yes it's Friday the thirteenth, and it looks like my radiator has gone. It seems to be leaking from the "crimp" join betwen the upper plastic piece and the metal core of the matrix Top front offside of radiator. Is this the normal way these rads fail? I've just had a quick look on E-bay and they seem to vary from £100 to £200. Obviously I do not want to spend more than I need to. Could someone with experience of these products advise please, the good the bad and the ugly as it were.
Hwyl a Fflag
95 silver 2WD AFT 2.5td, '96 Yamaha XJR 1200, '97 Buell S1 Lightning, '40 Indian Chief
Re: Leaking radiator
Post by Northern Bongolow » Fri Aug 13, 2010 2:31 pm
thats the usuall place.its the hotest point.
Post by missfixit70 » Fri Aug 13, 2010 2:36 pm
Seems to be a common fail point, some people had success by tightening the crimps over, but it's a bit of a gamble.
I went for the JAS rad after a few reccomendations on here - http://www.japautosolutions.com/acatalog/cooling.html it's identical to the factory fit rad, all fits in fine & does it's job fine.
Just make sure the passenger side oil cooler connection is tightened up properly, they leave it a bit slack to be able to adjust it apparantly, I thought I'd tightened it up enough, but it was still weeping slightly, needs to be really well tightened, not a big issue, just thought I'd mention it :wink:
321Away
Post by 321Away » Fri Aug 13, 2010 4:45 pm
i've fitted lots of different rads from various sources and have never had any problems with the ebay versions, some of the ebay types are all metal construction
Julian
al & chris
Post by al & chris » Fri Aug 13, 2010 11:59 pm
We went for JAS seems fine.
lars
Post by lars » Fri Sep 24, 2010 11:04 pm
It would have been a bit pointless asking for advice and recommendations and then ignoring them, so I bought a radiator from JAS, total cost £153.50. It looks identical to the original and as mentioned that loose auto box cooler pipe is a bit odd. I tried to follow the "Fact Sheet" way but of the ten bolts holding fans and pipe guides, two came out, two sheared and the rest spun in the plastic. As I now faced a lot of work to remove these I looked again only to see that the fact sheet was creating work, there was no need to grovel under the vehicle to undo the fans at all! 1. Remove top air duct. 2. Remove lower duct. 3. Remove electrical connections to fans 4. Remove all pipes from rad blocking as necessary. 5. Remove top rad retaining brackets. 6. Remove rad complete with fans. 7. Now comfortably remove fans from rad on the bench. Thanks for the help once again.
Hwyl a Fflag
mikexgough
Post by mikexgough » Sat Sep 25, 2010 7:29 am
Result ...............and some good additional tips....
321Away
Post by 321Away » Sat Sep 25, 2010 9:18 am
Thats how i do rads, from the top, if you undo the oil cooler pipes where they go from metal to rubber (against off side rail) then its a lot easier and doesnt require removing bits underneath and as you state you can remove everything esle on the bench. When you remove several radiators a week for kettle tests its the only way to do it.
Julian
