Two types of front blower motor?
brorabongo
Post by brorabongo » Tue Sep 21, 2010 7:09 pm
Just received today from a scrappy a motor, it looks different but I thought as there was only one motor for a 2.5 diesel I could'nt go wrong....well..... I did. :( I've emailed the scrappy to see where we go from here.
Black one the original.
What Bongo is the replacement one from?
ボンゴの激怒 pictures
rita
Re: Two tyres of front blower motor?
Post by rita » Tue Sep 21, 2010 8:07 pm
Is it my eyes,are the fins going in a different direction.
Cheers..
mister munkey
Post by mister munkey » Tue Sep 21, 2010 8:10 pm
Is it my eyes or should that read Two Types Of Front Blower Motor ? (EDIT: Yes it should... it does now. :wink: )
Tyres in there are only going to cause grief. :roll:
jaylee
Post by jaylee » Tue Sep 21, 2010 8:54 pm
mister munkey wrote:Hi
Unless you drive an old shape Fiat Panda... The spare used to go under the bonnet! :wink:
Brorabongo; I take it it wont fit into the fan case assembly??
carlioll
Post by carlioll » Tue Sep 21, 2010 10:01 pm
Just a thought but you did specify that your vehicle is a Mazda Bongo FRIENDEE? The fan you have may be for a Bongo Brawny or even a b2000 van. Might be worth checking with your supplier.
jaylee
Post by jaylee » Tue Sep 21, 2010 10:20 pm
Come to think of it...! It could possibly be the rear heater fan..??? http://www.lushprojects.com/bongopartsm ... mgno=.html Though no picture can be found of the actual unit, i've had my hands in there & seem to remember the fan drum diameter a little smaller than the front fan... :-k
brorabongo
Post by brorabongo » Tue Sep 21, 2010 11:29 pm
jaylee wrote:Brorabongo; I take it it wont fit into the fan case assembly??
Yep, won't fit and the eyes for the screws don't match.
mister munkey wrote:Is it my eyes or should that read Two Types Of Front Blower Motor ?
:oops: Could a mod or admin please correct my spelling please. :oops: must of been a senior/blond moment. (Edit done.)
carlioll wrote:Just a thought but you did specify that your vehicle is a Mazda Bongo FRIENDEE? The fan you have may be for a Bongo Brawny or even a b2000 van. Might be worth checking with your supplier.
Will do. :wink:
jaylee wrote:Come to think of it...! It could possibly be the rear heater fan..??? http://www.lushprojects.com/bongopartsm ... mgno=.html Though no picture can be found of the actual unit, i've had my hands in there & seem to remember the fan drum diameter a little smaller than the front fan... :-k
Is'nt the rear fan more cylindrical? I'm sure I seen a picture of one somewhere.
rita wrote:Is it my eyes,are the fins going in a different direction.
Will that mean it would suck instead of blow. :shock: :lol:
ボンゴの激怒 pictures
Post by Northern Bongolow » Wed Sep 22, 2010 2:33 am
i have a rear motor and complete unit in the shed i will look at it in the morning and post,
rita
Post by rita » Wed Sep 22, 2010 9:36 am
Quote..
Hi Donald,
That's exactly what will happen,you will probably find that the rotation of the motors are different also.
Cheers... :)
321Away
Re: Two types of front blower motor?
Post by 321Away » Wed Sep 22, 2010 11:35 am
The shiny motor is from a new shape heater system, the other is from an old shape and aren't interchangable.
Julian
brorabongo
Post by brorabongo » Thu Sep 23, 2010 12:17 am
Thanks to the admin/mod for correcting my silly spelling mistake in my title. Hope the correction does'nt confuse folk, after they read mister munkey's post.
Update: The seller has replied quickly to my email =D> , and were trying to resolve the problem.
ボンゴの激怒 pictures
brorabongo
Post by brorabongo » Fri Sep 24, 2010 12:53 am
Anyone got a bongo blower handy? as I'm too lazy to whip my old one out again....does this one measure up right, Cheers.
It's from a Mazda Rx-7, and it is a denso part. It looks good to me.
Thanks to Heathrow Jap Spares, for the photos, and trying to get me sorted. =D>
ボンゴの激怒 pictures
brorabongo
Post by brorabongo » Sun Oct 03, 2010 6:26 pm
RX-7 blower does not fit. Just a wee bit too small, by a few millimeters.
I made one good blower out of the two. Used the new one's armature, brushes and rear bearing, and the old one's top cover and blade. As can be seen the armatures were the same, but the brushes were slightly smaller on the new one.
bearing seized on old one.
draught excluder as a new seal.
Air vent cut-out in the ducting where the rubber pipe from bottom of motor connects. Could this be why moisture gets into the bearing case?
RX-7's (white one) blades in the opposite direction.
It now works well with no noise. \:D/
ボンゴの激怒 pictures
dunslair
Post by dunslair » Sun Oct 03, 2010 9:25 pm
I think Jaylee has hit the nail on the head Donald. I am 99% sure that what you have there is a rear fan. When I replaced the rear heater matrix I had the whole unit from Bongobits (tank baffles, aircon unit, heater matrix and fan) I stripped the bits I wanted, and because the rest was much older than mine, and I could not guarantee the electical elements, I binned the rest #-o But I am sure that is the same as the rear fan unit, and if you look at the lush drawing the direction of the fins makes sense :wink: That said i am surprised that the scrappie would take the trouble to take the whole rear unit apart, and not just sell the whole thing as BB did...
