RUST RUST AND MORE RUST
mazzabongo
Post by mazzabongo » Wed Sep 01, 2010 1:01 am
hi
I have a 98 Bongo with full conversion and I love it but the rust is really starting to creep in and the wheel arch is disappearing can anyone suggest what to do
bobngo
Re: RUST RUST AND MORE RUST
Post by bobngo » Wed Sep 01, 2010 8:56 am
sell it !!! if its that bad,
take the conversion out , and all extras you have on it , sell it,
buy an MPV version (check for rust this time ,all mechanical parts can be changed , rust is not beatable in the long term, )
refit your conversion into the new bongo and all the extras, and life can start again, nice winter project ???
some photos would help, maybe its not as bad as you think , but this forum can,t really help unless they can see the problem areas
wormey
Post by wormey » Wed Sep 01, 2010 9:43 am
Can't you have new arches put on, I saw that somewhere on here. That may get rid of the rust in this area. It's worth a search and a pm to the people on the forum who have done it. :D
Daz and debs
Barrington
Post by Barrington » Wed Sep 01, 2010 9:59 am
Yep new arches are the way to go if the engine is sound and the rest of the bongo then simply replace the arches :)
stick your location in people can then advise who may be best to do the job for you,,
Music is my Sanctuary!
321Away
Post by 321Away » Thu Sep 02, 2010 2:53 pm
Find a decent bodyshop and they'll cet the arches back and put new it, lots of people use ford transit arches as they're quite similar, big job, but if you plan on keeping the vehicle it has to be done, get all the box sections and internal traps waxoyled/undersealed too.
Julian
dobby
Post by dobby » Thu Sep 02, 2010 9:39 pm
mazzabongo wrote:hi
Give a clue to your location and someone may even recommend a body shop local to you.
Post by Doone » Thu Sep 02, 2010 9:47 pm
Find a decent bodyshop and they'll cut the arches back and put new it, lots of people use ford transit arches as they're quite similar, big job, but if you plan on keeping the vehicle it has to be done, get all the box sections and internal traps waxoyled/undersealed too.
=D>
We have to have a bit of bodywork done on ours. :) If there's rust on the arches, check the front and rear crossmembers too. They can be welded if they're not too bad, or cut out and replaced if they're badly corroded.
