Smoky start-up
jonah224
Smoky start-up
Hi, new to Bongoing, Got a 2.5D Auto, had a mechanic check it out when I bought it (fresh import). When I start it up in the morning or on the staff car park when it has been sitting for a while there is a large cloud of smoke from exhaust.
Once it's warmed up this is not a problem.
Is this normal.
Is this normal.
- mister munkey
Re: Smoky start-up
Black, white or blue smoke?
jonah224
Re: Smoky start-up
I would say mainly grey
Re: Smoky start-up
If it clears quickly, I would suspect a glow plug failing, causing unburnt fuel, in that cylinder, to be chucked out. You'll probably notice it harder to start when the weather gets colder.
jonah224
Re: Smoky start-up
Thanks Francophile, will get my mechanic mate to replace glow plugs, hopefully this will solve problem
- mister munkey
Re: Smoky start-up
A tip in the short term, wait an extra 5 seconds after the glowplug light goes out before turning it over. This gives more time for a weaker plug to come up to temp.
See if that helps.
See if that helps.
jonah224
Re: Smoky start-up
thanks mister munkey
Just tried it out and....... no smoke!!
Goodenough4U
Re: Smoky start-up
fantastic,
this is excatly what mine has been doing.
down to dps for me now
the smoker
Re: Smoky start-up
mine to did this at barmouth . i started her up one morning and noticed smoke around the rear as i was reversing. then at the same time the parking beepers beeped and the woman from the next tent jumped to one side with a fag in her cod lips . i leaned out of the window and said . "smoking will kill ya . you know"
Re: Smoky start-up
what a great bunch of peeps on here, 2 peeps fixed on one thread.
David Edwards
Re: Smoky start-up
Mine did it too just after I had put in a whack of oil in tesco car park, just before I topped up with diesel..same thing a woman with a fag in her hand came from the car behind me complaining that the smoke from my bongo had "gone all over her" I smiled and said " well now you know how us non smokers feel when you cretins blow your disgusting fumes all over us" her face went purple, she went back to her car and obviously told her hubby in the drivers seat, I watched in the mirror as his face cracked and he started laughing like mad.Bet he got some stick.
