Cruise Control, Taking the plunge
Stuart Dunn
Post by Stuart Dunn » Thu Aug 26, 2010 9:33 pm
Hi all, I've finally decided to purchase a cruise control kit for my manual 2.5 diesel bongo.
I've chosen to purchase a Waeco Magic Speed MS300. Before I actually make the purchase is there any advice anyone can offer, and also could anyone tell me the colour of the cable for the speed sensor as this unit needs a speed sensor input. Any advice would be greatly received. :mrgreen:
dandemann8
Re: Cruise Control, Taking the plunge
Post by dandemann8 » Thu Aug 26, 2010 9:41 pm
Not sure about wiring but be sure to inform your insurance provider of your mod or your insurance could be invalid. :wink:
Bongo no more........... ;-(
Stuart Dunn
Post by Stuart Dunn » Thu Aug 26, 2010 9:47 pm
Yes good call, I might ask how it will affect my premium
Matt&JoyBongling
Post by Matt&JoyBongling » Fri Aug 27, 2010 1:19 am
Premiums should not change.
Call your company and find out who they will accept as a qualified person to check that your installation is correct. They allowed me to use an automotive electrical engineer in Bedford who confirmed that it was ok.
I have not heard of anyone fitting the Waeco Magic Speed MS300 - most people seem to have fitted the MS50 (I think).
Underground, Overground, Bongoling Free, the Bonglers of Bedford, common are we ...
scanner
Post by scanner » Fri Aug 27, 2010 9:03 am
Matt&JoyBongling wrote:I have not heard of anyone fitting the Waeco Magic Speed MS300 - most people seem to have fitted the MS50 (I think).
Yes check it is possible to fit it to a Bongo.
But looking here http://waeco.com/tmp/MS-300_EB_d_04.pdf it looks to be almost identical to an MS50 just updated a bit. Same actuator and possibly the same control box with an updated control pad.
How much do they cost? Last price for the MS-50 was about £140.
Stuart Dunn
Post by Stuart Dunn » Fri Aug 27, 2010 10:00 pm
The price at the mo is £204, the pre requisit is 12v, Vac pump, Mechanical throttle and speed or rpm signal, I have all apart from the wiring colours. These seem to be recommended for bongo's
scanner
Post by scanner » Fri Aug 27, 2010 10:37 pm
Stuart Dunn wrote:The price at the mo is £204, the pre requisit is 12v, Vac pump, Mechanical throttle and speed or rpm signal, I have all apart from the wiring colours. These seem to be recommended for bongo's
Yes - sounds just like an updated MS-50.
You obviously know where the vacuum take-off is on the pipe at the front of the engine then? No need to cut into any pipes.
The Great Pretender
Post by The Great Pretender » Fri Aug 27, 2010 11:56 pm
Before you jump, make sure you get a stalk activator. It makes setting and trimming as easy as using the wipers. :wink:
If I had to choose 1 thing that has improved the Bongo it has to be cruise control. :D :D :D
To infinity and beyond
Ron Miel
Post by Ron Miel » Sat Aug 28, 2010 4:57 pm
The Great Pretender wrote:Before you jump, make sure you get a stalk activator. It makes setting and trimming as easy as using the wipers. :wink:
Don't think there was a stalk controller to work with an MS-50 when I did ours - if anyone knows of one now, would be grateful for the info.
Agree it's the Number One upgrade :D
Stuart - this thread might help http://www.igmaynard.co.uk/bongo/forum/ ... 76&start=0. I subsequently changed the wrapped metal foil "LED reflector" at 8.) and 9.), to a convex mirror removed from one of those small Halfords stick-on overtaking mirrors, fixed below the controller with a lump of epoxy putty. I think I got the wiring colours from an earlier thread on cruise control, so a search here should give them to you.
Cheers.
Post by g8dhe » Sat Aug 28, 2010 5:31 pm
There appears to be one (stalk control) for the MS300 here http://www.waeco.com/en/4374_700.php?ar ... 25&sprID=2
Post by Bob » Sat Aug 28, 2010 5:53 pm
From memory the speedo sensor wire is blue/white, but be aware there are two wires this colour behind the dash pod. Now you know that it is obvious which one you want.
Don't try and use Scotchlocks as the Bongo wire is too thin for a good contact, and as said you don't need to cut any pipes for vacuum take off.
Lift passengers seat and at the front of the engine is a vertical vacuum pipe with a small T take off. Remove the rubber cover by pulling the very end with a pair of pliers, then push fit the pipe from your sensor.
Ron Miel
Post by Ron Miel » Sat Aug 28, 2010 6:19 pm
Bob wrote:>
>....you don't need to cut any pipes for vacuum take off.
Not on V6's BTW, although I know that's not the issue here.
Ron Miel
Post by Ron Miel » Sat Aug 28, 2010 6:22 pm
g8dhe wrote:There appears to be one (stalk control) for the MS300 here http://www.waeco.com/en/4374_700.php?ar ... 25&sprID=2
Thanks Geoff. I think I enquired about that one, and was told it isn't/can't be MS-50 compatible but I'll check back when I've got some time.
Stuart Dunn
Post by Stuart Dunn » Sat Aug 28, 2010 10:15 pm
Thanks all for the replies, all this info is really usefull, keep it coming.
Yes the MS300 can have the option of the stick from the columb, but also a steering wheel pod is available, so adjustments can be made from the steering wheel.
Also looked at a gold cruise, which to be fair I've never heard of, but this has a nice gear stick version, pretty useful if its a manual bongo like mine, but I would imagin useless with auto's as no need to use the stick really.
Going to start some more research, cheers all keep it coming.
mister munkey
Post by mister munkey » Sat Aug 28, 2010 10:24 pm
No idea if its relevant but I have a spare V6 MX6 which is about to be scrapped but before I bin it I'm pulling off all the relevant compatible Bongo bits - Obviously.
One of the nicer features of this old girl is the original Mazda cruise control with all the control gubbins on the (same as the Bongo) steering wheel. It looks very smart.
Is this of use to anyone with the savvy to retro fit to a Bongo or should it go to the crusher?
