Diagnostic socket V6
haydn callow
Post by haydn callow » Mon Aug 23, 2010 10:14 pm
Does anyone know where this is located on a V6 ??
http://www.coolantalarm.co.uk
Also BMW Clocks
jojay5
Re: Diagnostic socket V6
Post by jojay5 » Mon Aug 23, 2010 10:32 pm
Behind glovebox I think? Saw something like this when putting new stereo in at the weekend.
James, Jo & Erin
JAL/V6/LPG/Mushroom/Full Side Conversion/Cannon Forge Bed
Post by g8dhe » Mon Aug 23, 2010 10:46 pm
Yes and watch out its "upsidedown" as it were;
haydn callow
Post by haydn callow » Tue Aug 24, 2010 12:15 pm
Geoff...whats that "bottle" thingy with fluid in ??
Also BMW Clocks
haydn callow
Post by haydn callow » Tue Aug 24, 2010 12:16 pm
Ah....could it be a torch ??
Also BMW Clocks
You've Been Bongod
Post by You've Been Bongod » Tue Aug 24, 2010 12:18 pm
hadyn that deffo looks like a torch mate
jaylee
Post by jaylee » Tue Aug 24, 2010 12:23 pm
The level is dangerously low in that torch Geoff.... :shock: :wink:
You've Been Bongod
Post by You've Been Bongod » Tue Aug 24, 2010 12:27 pm
jaylee wrote:The level is dangerously low in that torch Geoff.... :shock: :wink:
should have had a coolant alarm fitted :wink:
Post by g8dhe » Tue Aug 24, 2010 12:29 pm
Yes :-) Its a shake torch in the flare holder, can't run out of juice! So long as I have a working arm!
jaylee
Post by jaylee » Tue Aug 24, 2010 12:33 pm
Does it have a self test on the level..? Like a bulb lights when all is well??
Post by bigdaddycain » Tue Aug 24, 2010 12:36 pm
g8dhe wrote:Yes :-) Its a shake torch in the flare holder, can't run out of juice! So long as I have a working arm!
A shake torch? You shake it and it lights up? :?:
You've Been Bongod
Post by You've Been Bongod » Tue Aug 24, 2010 12:38 pm
come on folks goin off topic here haydn needs some help with a problem so can we get back on topic =D>
Post by g8dhe » Tue Aug 24, 2010 12:41 pm
You got it one!
See http://tinyurl.com/37dgm27
He's found the connector by now I would hope ;-) Nothing wrong I hope Haydn ?I suspect like most of us, just want to know where everything is!
jaylee
Post by jaylee » Tue Aug 24, 2010 12:42 pm
You've Been Bongod wrote:come on folks goin off topic here haydn needs some help with a problem so can we get back on topic =D>
I thought Geoff had already shed some light on Haydn's question..?
.... I'll get back out to the garage now.. :oops:
Post by bigdaddycain » Tue Aug 24, 2010 12:46 pm
You got it one!
:D How cool is that? All i'd need then is a conventional battery powered torch so i could locate the shakey one! :lol: Nice one Geoff. :wink:
