Fuel Pump bleeding
affaj ekac
Fuel Pump bleeding
Post by affaj ekac » Sun Aug 08, 2010 8:52 pm
Hi all,
This is my Virgin post having read loads of good advice since getting Bongo in April. I have had to do loads to it as it sat for 18 months and every time I get there another little Gem pops up. I thought I had it last week when it was running fine but after changing the fuel strainer on the top of the pump it has power loss again. If I switch the engine off and then straight on again I get it back for a little bit. When the Bongo ignition is turned off a whizzing noise like an air loss comes from the pump. I am thinking I need to bleed the pump. Does this sound right and how do I do it, I am not the best mechanic but this site seems to help!!!!!!!!!
Virgin in distress needing help of any bongoites!!!
Re: Fuel Pump bleeding
Post by missfixit70 » Sun Aug 08, 2010 8:56 pm
Should be self bleeding, check you've not got a leak at the banjo filter after doing it. as it's on the suction side it will be sucking air in. If you've done anything else, go back & check it's all tight.
Post by Northern Bongolow » Sun Aug 08, 2010 8:58 pm
check the air vacuum pipes that are on the pump,sounds like not a fuel leak but an air leak imo
oh and welcome
affaj ekac
Post by affaj ekac » Sun Aug 08, 2010 9:08 pm
Hi Supreme Being,
Just checked fittings and they are all tight. It will just crank over now and not start up.
I had changed banjo filter last week and it was running fine then started losing power again, now after checking it again left with it just cranking over.
thanks for swift reply.....I love this site....even having a bongo that doesnt work makes me feel part of the bongo gang!!
affaj ekac
Post by affaj ekac » Sun Aug 08, 2010 9:12 pm
Ady,
Being a novice what does IMO mean (is it another one I need to ask the kids!) and I really am a novice I am a PTI who fixes bodies instead of campers.........may be out my depth...what/where are vaccum pipes?
Again thanks for swift reply.......trying to make Cornwall this week!!!!!
Steph
affaj ekac
Post by affaj ekac » Sun Aug 08, 2010 9:13 pm
Northern Bongolow wrote:check the air vacuum pipes that are on the pump,sounds like not a fuel leak but an air leak imo
oh and welcome
Just figured IMO out-In My Opinion- sorry thought it was technical term
Post by missfixit70 » Sun Aug 08, 2010 9:15 pm
Vacuum pipes - http://www.lushprojects.com/bongopartsm ... 1of02.html
Supreme being may be the rank but it ain't my name :wink:
affaj ekac
Post by affaj ekac » Sun Aug 08, 2010 9:20 pm
missfixit70 wrote:Vacuum pipes - http://www.lushprojects.com/bongopartsm ... 1of02.html
Thanks Fur Fox ache, Im getting it now- mines is affaj ekac, a riddle to keep me and the kids amused when people ask if we have name for bongo- if I get it off the drive!!!
Thanks for the link
Steph
Post by Northern Bongolow » Sun Aug 08, 2010 9:25 pm
someones heading for trouble :lol: :lol: :lol: :lol: :lol: =D>
affaj ekac
Post by affaj ekac » Sun Aug 08, 2010 9:26 pm
Northern Bongolow wrote:someones heading for trouble :lol: :lol: :lol: :lol: :lol: =D>
Think you may be right
Post by Northern Bongolow » Sun Aug 08, 2010 9:26 pm
check the link that KIRSTY put up then check all the thin air/vaccum pipes
Post by missfixit70 » Sun Aug 08, 2010 9:49 pm
Thanks for the link
Steph
Forum names are up on the top left of the post, ie where your jaffa cake is :wink: mine's Missfixit70, Ady's is Northern bongolow :wink:
Post by Northern Bongolow » Sun Aug 08, 2010 11:48 pm
i told you trouble was coming :lol: :lol: :lol: :lol: :)
Diplomat
Post by Diplomat » Mon Aug 09, 2010 9:09 am
What's a PTI?
I'm a novice!
Frank
They flew, I took up naturism
haydn callow
Post by haydn callow » Mon Aug 09, 2010 9:59 am
Phyical trg instructor.....
Does anyone have a lushprojects link the the vacuum pipes on a V6.....carn't seem to find that diagram.
http://www.coolantalarm.co.uk
Also BMW Clocks
