meek.tv
Post
by meek.tv » Tue Oct 20, 2009 10:38 pm
......has started illuminating when i come to a stop whilst facing down hill on steepish gradients. any ideas why
and no its not because i have put the handbrake on
.......... cycling more.
Post
by missfixit70 » Wed Oct 21, 2009 12:42 pm
I'd go with that Brora.
Sar N Ade
Post
by Sar N Ade » Fri Aug 06, 2010 7:14 pm
Our brake light came on in the Forest of Dean (a bit unnerving with all those hills...)
There is nothing in the handbook (apart from contact the Mazda dealer) and I couldn't see a fact sheet about the brake fluid.
So, what do we need to do if the light comes on? Do we need to top up the brake fluid or replace it? What type should we use? Or is it a garage mechanic issue?
Thanks in advance for any help
Sarah
haydn callow
Post
by haydn callow » Fri Aug 06, 2010 7:40 pm
Just check the level in the brake fluid tank under the bonnet....top up if required.
Post
by missfixit70 » Fri Aug 06, 2010 7:45 pm
Use DOT4 brake fluid. If it hasn't been changed in your ownership, may be advisable to get a garage to change it as it's supposed to be done every two years.You also need to find out why it's dropped, cos it shouldn't unless it's leaking somewhere.
mikexgough
Post
by mikexgough » Fri Aug 06, 2010 7:53 pm
Brake fluid is not considered a "top up" fluid. If it is low, there is usually a problem. Brake fluid level in the master cylinder will drop as the linings (pads or shoes) wear and the calipers or wheel cylinders extend further to compensate. This added fluid may need to be removed when renewing pads or shoes
Your brake pads maybe getting low, should you need to top up then use DOT4 and minimal amount, as if the pads are low then you will have to remove the excess you add...
Sar N Ade
Post
by Sar N Ade » Fri Aug 06, 2010 9:17 pm
Thanks everyone
Helpful advice as ever
We are now going to check the front and back brakes with a view to changing them before our next weekend trip.
I have printed off the fact sheet for reference.
Gosh this club is useful
Sarah
Rhinoman
Post
by Rhinoman » Sat Aug 07, 2010 12:29 am
mikexgough wrote:Brake fluid is not considered a "top up" fluid. If it is low, there is usually a problem. Brake fluid level in the master cylinder will drop as the linings (pads or shoes) wear and the calipers or wheel cylinders extend further to compensate. This added fluid may need to be removed when renewing pads or shoes
This is very true, the brake system is usually designed such that the brake light will come on when the pads are worn and need replacing. The fluid should only be topped up, if necessary, when the pads are replaced.
1995 Ford Freda, 2.5TD, auto, AFT, side conversion.
A1tony
Post
by A1tony » Mon Sep 06, 2010 6:57 am
I am guessing there could be other reasons. My brake warning light came on yesterday. Looking at the pads, they are nearly new. Going to check the sensor cables, if it's not that then maybe the handbrake needs adjusting. Either way I am not losing fluid so more investigation required !!
rita
Post
by rita » Mon Sep 06, 2010 9:33 am
A1tony wrote:I am guessing there could be other reasons. My brake warning light came on yesterday. Looking at the pads, they are nearly new. Going to check the sensor cables, if it's not that then maybe the handbrake needs adjusting. Either way I am not losing fluid so more investigation required !!
Hi,it sounds like your hand brake switch could be faulty.
dave_aber
Post
by dave_aber » Mon Sep 06, 2010 9:44 am
Try raising your roof with the handbrake off (but stopped, obviously!). If it works, it could be the handbrake switch.
Those that understand
binary, and those that don't.
scanner
Post
by scanner » Mon Sep 06, 2010 9:47 am
missfixit70 wrote:Use DOT4 brake fluid. If it hasn't been changed in your ownership, may be advisable to get a garage to change it as it's supposed to be done every two years.You also need to find out why it's dropped, cos it shouldn't unless it's leaking somewhere.
It will drop as the pads wear and more fluid is held in the calipers
A1tony
Post
by A1tony » Mon Sep 06, 2010 11:45 am
dave_aber wrote:Try raising your roof with the handbrake off (but stopped, obviously!). If it works, it could be the handbrake switch.
Roger that, I will, give it a go..
if it is the switch, where is it ? on the back of the lever mechanism or elsewhere ??
Many thanks
dave_aber
Post
by dave_aber » Mon Sep 06, 2010 11:47 am
Pop the centre console off, and it's right at the back of the handbrake lever.
