Fuel filter
Terry T
Fuel filter
Post by Terry T » Tue Aug 22, 2006 7:31 pm
I bought a filter kit for my Bongo, the air and oil ones were fine, the diesel one is completely different. My existing one has an electronic level sensor with a drain. The new one has a smaller bolt through hole and no place for the sensor.
Has anyone come across this before?
Taxiback
Post by Taxiback » Tue Aug 22, 2006 10:18 pm
Here is what it should look like. (click to enlarge)
The part number.
The bottom.
The top as you look down at it.
There is a black rubber O ring which goes on the bottom .
Hope you find this of help.
Simon Jones
Post by Simon Jones » Tue Aug 22, 2006 10:22 pm
It should have quite a big hole in the bottom & a new O-ring seal for the sensor. Should look a bit like this:
http://cgi.ebay.co.uk/Fuel-filter-Mazda ... dZViewItem
If not, sounds like the wrong part has been supplied.
Terry T
Fuel Filter
Post by Terry T » Wed Aug 23, 2006 6:00 pm
Thanks for your replies, but this filter with the same serial number is the one that has been supplied and certainly isn't the one in my Bongo!!!!!!!!!
If I knew how to show you some snap shots i would![/img]
Peg leg Pete
Post by Peg leg Pete » Wed Aug 23, 2006 8:30 pm
Probably the wrong filter in the wrong box!
Image Pete
Taxiback
Post by Taxiback » Thu Aug 24, 2006 1:19 am
Take a picture and send it to me at [email protected]
