Problems with the rear window blinds
fergs
Post by fergs » Thu Jul 29, 2010 2:07 pm
I have just bought my first ever Bongo I must say that I love it already :D
One thing I cant seem to get the hang of though, is closing the rear window blinds....
Mine has the manual ones & not the electric version & I can close them fine but when it comes to opening them, they seem to get stuck half way up or wont open at all :(
I'm sure there is probably a simple knack to doing this but struggle as I might, I don't seem to be able to work it out .....
Any of you guys care to point me in the right direction please ?
Thanks is advance :D
daveblueozzie
Re: Problems with the rear window blinds
Post by daveblueozzie » Thu Jul 29, 2010 5:03 pm
Mine are the same, just be a bit forceful, they seem to be quite robust, there are notches and you have to force the blind past the notches.
Lost without my Bongo.
roofraisers
Post by roofraisers » Thu Jul 29, 2010 9:34 pm
If you can "unclip" one side & then let the blind go up with the lower rail on a diagonal, that will aid you past the notches.
Nigel
Allans
Post by Allans » Thu Jul 29, 2010 10:27 pm
On the bottom of the blinds, there're 2 pins going in to the channels. Each pin should have a block on it. The blocks can fall off. If they do, the blind doesn't run smoothly. You can get a spare block from a breaker.
Or you could try a squirt of silicone spray in the channels.
fergs
Post by fergs » Wed Aug 04, 2010 10:40 am
Thanks for the replies everyone - It does appear that the blinds are missing some of the blocks on the ends of the pins so I will try & find some replacements as suggested.
