Everything was working fine today, but come this evening and now only the driver's door opens or closes when using the remote key fob.
I have done a 'search' but can find nothing related to my problem.
The only way we can open any of the other doors is by using the key.
Is it a problem with central locking memory?
Central Locking problem
It/they will have become intermittant in the rubber flexible tube coming out of the door.
I have not had this particular problem myself but I suspect that if he removes the panel he will be able to pull the wires to see if any are broken.
He might also have to remove the trim by the pillar where it goes into the Bongo itself.
Actually thinking about it, you can hear the clonking of the lock in the door trying to open which may indicate that the problem is in the pillar rather than the panel, especially as it is the passenger door as well as the sliding door which are affected. Or is that an over-simplification of a diagnosis?
Mrs. D
Mrs. D
