New TV/DVD
the guvnor
New TV/DVD
Post by the guvnor » Fri Jul 16, 2010 11:08 am
hi guys.
Prob a silly question , but me and electrics do not mix !!! :oops: #-o
I have recently bought a tv for my bongo.......normal tv to plug in mains when on site. I have set it up and found it has a 12v power cable plugging into a 240v adaptor. Does this mean I could in effect not use the adaptor and plug the tv into the ciggy lighter ??
Be a result if i can !!!!! :lol: =D>
Cheers guys
munroman
Re: New TV/DVD
Post by munroman » Fri Jul 16, 2010 11:30 am
Indeed you should be able to do this, just be sure if it is the starter battery powering it that you leave enough in the battery to start the Bongo!
When asked about Western Civilisation, Ghandi said 'that would be a good idea'...
Re: New TV/DVD
Post by francophile1947 » Fri Jul 16, 2010 12:18 pm
I tend to use mine on 12V all the time - just don't run the engine whilst watching it, as I'm not sure the TV will like 14V :?
Alison01326
Re: New TV/DVD
Post by Alison01326 » Fri Jul 16, 2010 2:23 pm
francophile1947 wrote:I tend to use mine on 12V all the time - just don't run the engine whilst watching it, as I'm not sure the TV will like 14V :?
:shock: :shock: :shock: We use our portable DVD player on 12 volt whilst driving along. Doesn't appear to have done it any harm. Should we just use it on battery then? Don't know about these things.
Alison
Re: New TV/DVD
Post by g8dhe » Fri Jul 16, 2010 3:47 pm
If a portable device is designed to use the supply from a car (i.e. it came fitted with a Cigar plug) then it will probably be perfectly OK. However lots of devices actually run on 12 volts and use a mains supply which will drop and regulate the supply to exactly 12 volts, if the set didn't come with a supplied cigar lighter lead then you need to be wary of just connecting it to such a lead.
A car 12 volt supply is ONLY nominally 12 volts it will range from 10 volts to 14.5 volts as an average value and can have some seriously powerful spikes with a lot of energy in them. Plenty of devices won't like average voltages much in excess of 12 volts, they probably won't do anything nasty but might not have a very long life as they may be over heating. Very few devices will put up with the typical voltage spikes that will appear from time to time it is these that will probably cause a device to fail with no warning at all.
Re: New TV/DVD
Post by francophile1947 » Sun Jul 18, 2010 12:56 pm
g8dhe wrote:If a portable device is designed to use the supply from a car (i.e. it came fitted with a Cigar plug) then it will probably be perfectly OK. However lots of devices actually run on 12 volts and use a mains supply which will drop and regulate the supply to exactly 12 volts, if the set didn't come with a supplied cigar lighter lead then you need to be wary of just connecting it to such a lead.
Mine is a normal 19" domestic TV/DVD with a transformer in the supply lead, that's why I don't risk it :wink:
Darkstar
Re: New TV/DVD
Post by Darkstar » Tue Jul 20, 2010 10:25 pm
i use a regulated dc to dc variable converter, had no probs yet, just need to make sure you plug adapters right way,
http://www.mellorautoelectrical.co.uk/C ... utput.html
just make sure you get polarity right, usually tip is positive.
Got a Bongo for the Wife, Best trade-in ever
Rhinoman
Re: New TV/DVD
Post by Rhinoman » Fri Jul 23, 2010 11:24 am
g8dhe wrote:A car 12 volt supply is ONLY nominally 12 volts it will range from 10 volts to 14.5 volts as an average value and can have some seriously powerful spikes with a lot of energy in them. Plenty of devices won't like average voltages much in excess of 12 volts, they probably won't do anything nasty but might not have a very long life as they may be over heating. Very few devices will put up with the typical voltage spikes that will appear from time to time it is these that will probably cause a device to fail with no warning at all.
Thats very true, when we design automotive components they have to withstand spikes of around 200V and have immunity from surges of around 60V. Unless its designed for a car supply then don't use it with the engine running.
You can probbaly use a universal car laptop converter to run a dvd or similar, that would be more efficient than a 240V inverter. I use one very similar to the one linked to by Darkstar.
1995 Ford Freda, 2.5TD, auto, AFT, side conversion.
Re: New TV/DVD
Post by francophile1947 » Fri Jul 23, 2010 11:28 am
Rhinoman wrote: You can probbaly use a universal car laptop converter to run a dvd or similar, that would be more efficient than a 240V inverter.
It certainly is better than using an inverter 8) Never had any problems using my laptop with the converter, but it often wouldn't work with a 150W inverter, especially if the laptop's battery was low.
