Timer switch?
Timer switch?
Hello I am a new member and new owner of my first Bongo please can anyone tell me what the timer is for? it is just to the left of the steering wheel on the dashboard. thanks Lorna
Its for the Intercooler.. I think!
Im Guessing its a timer fitted that when set, leaves your engine running after you remove the key?
If this is the case its likely to be a timer for the intercooler. I will probably get this wrong but the intercooler is part of the turbo, which has some oil filled bearings in it, if the turbo has been working hard & you stop the engine, the turbo will be hot & burn the oil in ther bearings out.
The timer leaves the engine ideling & the intercooler going so that the turbo is cooled down slowly, preventing the oil in the turbo from burning & therefore prolonging the life of the turbo.
Am I right? anyone?
Im a newbie to only had the bongo a few weeks!
By the way I should add, that I believe turbo timers are illegal in this country as they leave the engine running while the car is unattended. But then again a lot of things are illeagal, but it dosent stop some of us doing them
Stuart
Am I right? anyone?
Stuart
Yep,
I reckon its a turbo cool down timer. Had one on a Townace.
Not a bad idea just bloody stupid to be able to leave the engine running with no one in the seat.
If weve been cruising fast on the motorways for miles we generally do the final few miles a bit slower to let the turbo cool down slowly.
Bonz
Bonz
Illegal to use on the public highway but it is not illegal to have one fitted. You can use it when you are on your own property. They are also a very handy tool to have on vehicles with larger turbos as a means to remind you not to turn of the engine, after a good long run and let the turbo cool down. The legality of them only comes into question if you have actually left the car, and it is running unattended.pippin wrote:Can confirm that these timers are illegal to use on the highway in UK/Eu.
It should have been removed at import/SVA.
I think that is the right decision but DO NOT forget to let the engine idle for a minute after a short run, a couple after a long one. If pulling in for fuel on the motorway where it is not possible/advisable to idle the engine at the pumps, relax the speed for the last 10 miles or so.
This is to preserve the life of the turbo.
I find that this practice is easy to remember in practice.
Bongo National Party - The law-abiding should have rights too!
- dandywarhol
Sorry to be a bit blunt here Paul but this 10 mile relaxation thingy is absolute overkill.Kentish Paul wrote:I think that is the right decision but DO NOT forget to let the engine idle for a minute after a short run, a couple after a long one. If pulling in for fuel on the motorway where it is not possible/advisable to idle the engine at the pumps, relax the speed for the last 10 miles or so.
The turbine does run at very high speed, up to 100,000 rpm, but there is little mass in its internals so returns to zero very quickly.
The reason to keep the engine running is to ensure a supply of pressurised oil to the turbo bearings while it slows down.
Even after a motorway high speed run into a service station it is quite sufficient to let the engine idle for a minute or so before turning off - just enough time to dig your wallet out of the usual hiding place and to open the fuel flap
