carpet removal for fuel sender panel
nickgoodson
Post by nickgoodson » Fri Aug 11, 2006 12:14 pm
Any ideas how to remove the carpet for accessing the fuel sender panel on the fuel tank please? know roughly where the panel is but the carpet seems well and truly fixed. thanks.
David Edwards
Post by David Edwards » Fri Aug 11, 2006 12:31 pm
Well if you mean the flap under the rear most seats, its easy, ( must be because I did it), just slide the rear seats as far back as poss, slide the middle seats forward as poss, this will give plenty of room, grab the carpet and give it a good tug, it will come up allowing access to the flap, when my sender failed I ended up making another earth for good measure, the carpet went back easy as well, it may take quite a tug to start but keep going I gave everything a good clean and spray with grease but remember to test it before you put things back, I didnt and ended up doing it twice. good luck happy motoring.
nickgoodson
Post by nickgoodson » Fri Aug 11, 2006 12:47 pm
Thanks for that, I'll give it a go later. Fingers crossed.
nickgoodson
Post by nickgoodson » Fri Aug 11, 2006 1:03 pm
Dave,
Just to confirm, you say move the rear seats back as far as they will go, but my rear-most seats fold up out of the way, is it the same for all Bongos?
nickgoodson
Post by nickgoodson » Sun Aug 13, 2006 7:53 pm
I tested the fuel sender unit, it appers that it is definitely faulty. Gauge reads zero when disconnected and when you earth the live supply it reads max, gauge works fine, also there is 3.6 V in the circiut. Found a good earth, still not working. Anyone know where I can get a new sender unit from please? Thanks.
Nick
Post by Ian » Sun Aug 13, 2006 8:59 pm
Try Vospers on 01392-203802
David Edwards
Post by David Edwards » Sun Aug 13, 2006 9:08 pm
Sorry been partying only just come round. No there are loads of variants, some have the bench rear seat as mine, other the fold up like yours, ( which I would love) and the rest have some ugly kitchen or other cluttering up the rear end.( oh I expect I am for it now). Happy motoring.
nickgoodson
Post by nickgoodson » Sun Aug 13, 2006 10:15 pm
Thanks for that.
nickgoodson
Post by nickgoodson » Mon Aug 14, 2006 11:29 am
Just had a quote from Vospers for new fule sender unit, ?253.94, bloody hell. Somebody said you can get for about ?90, anybody know where from? Thanks.
