Axle Oil - what type please?
pbe1973
Post by pbe1973 » Mon Jul 05, 2010 11:13 am
Hi there - Is the oil you use for the Axels a special type or the standard 10W - 30 used elsewhere?
Re: Axle Oil - what type please?
Post by francophile1947 » Mon Jul 05, 2010 11:29 am
Definitely not 10w/30.
It's an EP oil but are you talking front or rear axle and do you have a limited slip differential?
There's a Lubricants fact sheet in the Member's Area 8)
pbe1973
Post by pbe1973 » Mon Jul 05, 2010 2:32 pm
Hi SB
Thanks for the reply - Just read the factsheet. Mine's 2.5d 4WD, so it looks like SAE90 (GL5) on both the front and back.
Thanks again
Post by Northern Bongolow » Mon Jul 05, 2010 3:19 pm
hi ive just done my oils
front dif, rear dif,transfer box,with a product called millars syntran 11 great results and 100000 miles change interval,so thats it done for ever!!
what you must check though is whether you have limited slip difs,the oils for these are different,
mine are standard difs,not limited slip.
hope this helps.
pbe1973
Post by pbe1973 » Mon Jul 05, 2010 3:25 pm
Brilliant - thanks NB
pbe1973
Post by pbe1973 » Mon Jul 05, 2010 3:26 pm
PS - where did you buy it from? Is it widely available?
Post by missfixit70 » Mon Jul 05, 2010 6:16 pm
Any motor factors or Halfrauds etc will have it.
PeterP
Post by PeterP » Mon Jul 05, 2010 7:27 pm
How do you know by looking if you have a LSD or not?
Alison01326
Post by Alison01326 » Mon Jul 05, 2010 7:33 pm
PeterP wrote:How do you know by looking if you have a LSD or not?
Wait until a technical bod gives you a proper answer, but meanwhile, you might be able to find out by entering your VIN number here http://www.ruzip.ru/eumz/eumzcat.aspx
Alison
Post by missfixit70 » Mon Jul 05, 2010 7:36 pm
Put your vin no in the lower set of boxes on this site
sgl3 or whatever in the first box & the rest of the number in the 2nd box, it'll tell you whether its a normal or limited slip diff, don't even need to go outside :wink:
Too slow #-o :lol:
