front fan help
front fan help
My fan has stopped working - but following instructions in member factsheet fan runs with power directly attached.
i have removed the resistor and it looks ok - no sign of burning - so with this removed should the fan run ?
or do you need to short some cables...
is there a way of testing before spending money on a new one I may not need..
thanks
thanks
- missfixit70
Re: front fan help
Have you checked the factsheet on repairing the resistor pack? links in the FAQ posted above.
Re: front fan help
yes factsheet says to replace the resistor if the motor runs only when on max setting.
my fan motor does not work on any setting - yet powering it directly from battery its ok.
Could it still be the resistor - at £80 a go I would like to know if there is a way of testing
could something else stop power to the fan ?
- missfixit70
Re: front fan help
There's a factsheet on checking/repairing the fan speed resistor, all links in the FAQ - http://www.igmaynard.co.uk/bongo/forum/ ... 43&t=28727
Worth checking to see if there's voltage getting to the resistor controller pack, also there are relays behind & below the driver side headlight, also check the fuses, listed in the fuses factsheet.
- missfixit70
Re: front fan help
Same question asked here - http://www.igmaynard.co.uk/bongo/forum/ ... =5&t=37740 probably best to lock this one to prevent confusion.
Re: front fan help
thanks for these -
so it says that if the resistor has broken fan will still operate at full power only.
If mine does not operate at full power and fuse is ok what then ?
previous post says if relay has gone air con fan doesn't work.
my air con fans come on ok.
fan motor works ok when directly powered
Re: front fan help
Looking at the circuit there are three obvious possibilities;
One the relay isn't operating to turn the Fan on at all, or secondly the left most fusible link has blown (in the pack) or if the resistor pack isn't fitted then the Fan won't turn at all of course.
Re: front fan help
Weird cos I had read that too but when mine packed up t'other day the fan didn't work at all and the aircon would only work when fan setting was at number 1 position. Turned out all tabs on resistor had de-soldered (I suspet it must all depend on which tabs have de-soldered). Very simple to fix though if you can wield a soldering ironmurphy wrote:thanks for these -
Re: front fan help
thanks for advice -
can you tell me if there is a way of bypassing the resistor pack - to isolate that as a fault.
ie shorting it ...
i put a volt meter on it and none of the three input pins has voltage though
ie shorting it ...
Re: front fan help
Not tried that. Easy enough though (using factsheet, and it is VERY easy) to open up resistor and you will see at once if (some) tabs have desoldered. I'd approach the problem that way personally. Good luckmurphy wrote:thanks for advice -
ie shorting it ...
Re: front fan help
There are 5 pins in all, and when the relay is operated with the switch set to LOW, then all of the pins, other than the LOW one, should have a a small voltage on them I would guess 2-6 volts.murphy wrote:i put a volt meter on it and none of the three input pins has voltage though
If None of them have a voltage on then either the left hand fuse has melted, or the relay isn't operating - my bet would be on the fuse!
Re: front fan help
thanks to everyone who contributed to assist me.... ran of options now for me.... can anyone recommend a bongo friendly garage or person in hertfordshire ( st albans) i can take it to... don't really want to hand it over to my local garage which have been good with mechanical issues but they may struggle with this .......
cheers
cheers
Re: front fan help
I had a similar problem to this, my resistor pack blew all the soldered connections but not a fuse. Fitted a new resistor pack and it did the same thing, obviously a dead short but still did not blow a fuse. Turned out the fan motor was seizing in its bush it was stiff to turn by hand,I stripped the motor, cleaned the spindle, oiled it and after resoldering the connections all is now working fine.
Re: front fan help
The "soldered" connections ARE the fuses - thermal fuses! They use a slightly softer solder mix which melts at a given temperature. The fuses in the boxes are there to protect the wiring not the devices themselves, they won't go until you have a wiring short. Motors are quite difficult things to fuse, in normal operation they will draw several times the average current at start up, so any form of normal fuse will blow at start up if it is rated to protect the motor during normal running, however if you rate it for start-up then it will never blow given a fault during runningjohnny7 wrote: my resistor pack blew all the soldered connections but not a fuse.
Hence the use of the thermal resistors connected with the speed limiting resistors that get hot in normal operation.
