saracen
Post
by saracen » Thu Jun 03, 2010 1:05 pm
There are two small round buttons in my Bongo that I'd like to identify - as you can see from the photo, one is to the right of the steering column, near the ignition, and the other is on the left of the steering column and a little lower down. They don't seem to do anything, but I'd like to know if possible...
Thanks!
mobilecat
Post
by mobilecat » Thu Jun 03, 2010 1:07 pm
The switch on the right looks like the one I had when I had lights on my bullbars. I suspect these are bullbar lights or little lights at the front. Get out and have a look
Post
by missfixit70 » Thu Jun 03, 2010 1:11 pm
One's probably rear fog, will only be on when lighnts are on, they're aftermarket switches so could be anything.
TechnoTurkey
Post
by TechnoTurkey » Thu Jun 03, 2010 1:36 pm
As Kirsty said, these have been fitted by a previous owner and could do anything! Best bet is to try and trace the wires, do the leds light up when you turn the switch on?
If not they either didnt connect the earth for the led on the switch or whatever they used to do has long since gone!
Member 10,000!
1997 Green AFT 4x4 2.5TD Auto Bongo
mcbainia
- Bongonaut
Post
by mcbainia » Thu Jun 03, 2010 1:52 pm
I concur - the button to the lower right of your steering wheel is for your rear fog light. It will light up orange when you switch it on (and your rear fog light will come on) - but only when you have your main lights on. I have exactly the same switch in the same place on mine.
You can lead a horse to water but you cannot make it swim
saracen
Post
by saracen » Thu Jun 03, 2010 3:12 pm
Cheers all - the right hand button is indeed the fog light. Had been wondering where this was! The left hand one remains a mystery.
saracen
Post
by saracen » Thu Jun 03, 2010 3:34 pm
This left-hand button - I have been having a bit more of a play with this and I've noticed that when it is turned off (or what would be the off position if it works exactly like the other one) it produces a 'boing' sound. We had noticed this sound before - and had thought it might be associated with battery issues (it happened when the battery was flat), but it now occurs to me that given the position of this button it may be happening simply because I am knocking the button on and off with my knee. Can anyone help with what this boing might mean? Is it an alarm system of some kind? Am I going to have to trace wires and if so how would I go about this?
Thanks again!
Post
by Muzorewa » Thu Jun 03, 2010 3:36 pm
Probably the Zebedee button
321Away
- Tribal Elder
Post
by 321Away » Thu Jun 03, 2010 3:56 pm
it utrns on/off ur reversing sensors, u prob have a button to left of steering wheel that says sonar, where u can turn the sound on/off
Julian
saracen
Post
by saracen » Thu Jun 03, 2010 4:52 pm
thanks Julian - that seems to be the one!
Cheers -
Gill
dunslair
Post
by dunslair » Thu Jun 03, 2010 4:59 pm
321Away wrote:it utrns on/off ur reversing sensors, u prob have a button to left of steering wheel that says sonar, where u can turn the sound on/off
Julian
Ah ha... the 'sonar parking sensor button'...So nar and yet so far
Must be pims O clock....
