Help needed roof tent issue,,
Hi guys need a bit of your advice of late my roof wont go to its stop position it goes all the way to the top but wont stop bleeping untill i give it the extra shuv to the last inch or so then bleep stops,, is ther anything that needs adjusting to reset the stop position? many thanks barrington,
Music is my Sanctuary!
- daveblueozzie
Re: Help needed roof tent issue,,
Join the club
loads of us have the same problem its just a small inconvenience.
Lost without my Bongo.
- Bongonaut
Try unzipping the tent front a little before you lower it. It helps to expel the air, but it also means that there's a slightly less strain when you open it next time.
- missfixit70
A bit of lube on the moving bits may help too.
so guys what actually causes it?, its only just started doing it, is there any over run on the runners i can adjust,
It's the weight of all that "BLING" holding it downBarrington wrote:so guys what actually causes it?, its only just started doing it, is there any over run on the runners i can adjust,
Bongo no more........... ;-(
- missfixit70
tent fabric being stiff after a long cold winter? mechanism needs lubing therefore a bit more friction for the motors to overcome? motors getting a bit older?
Tried that made mine even stiffermissfixit70 wrote:A bit of lube on the moving bits may help too.
Always be ready for a Top Up!
Baz what you likebongobaz wrote:Tried that made mine even stiffermissfixit70 wrote:A bit of lube on the moving bits may help too.
I know . i've just finished work too
- mister munkey
Try a bit ot this
In the runners & rams a couple of times a year.
Works for me.
Works for me.
dandemann8 wrote:It's the weight of all that "BLING" holding it downBarrington wrote:so guys what actually causes it?, its only just started doing it, is there any over run on the runners i can adjust,![]()
Ok chris thanks mate will give it a shot, so nothing to adjust then?
- mister munkey
I.m sure technical adjustments are available but in the early stages of Middle Aged Sticky Roof Syndrome the spray works for me,
- missfixit70
I think one or two have found a microswitch has moved slightly? A search may find an answerBarrington wrote:Ok chris thanks mate will give it a shot, so nothing to adjust then?
