You've Been Bongod
Post
by You've Been Bongod » Tue May 25, 2010 8:35 pm
i have had a cat 1 alarm and rear camera fitted this week
anyhow now the n/s rear speaker doesnt work
changed the speakers for new ones and the n/s still no work have checked the speaker thats ok but no power to the speaker wires on the n/s
before i run new wires from o/s to n/s any ideas would be welcomed
David Edwards
Post
by David Edwards » Tue May 25, 2010 8:46 pm
Strange my rear nearside speaker is not working either, the speaker is ok but like you I am gonna have to search.lol.
Post
by Doone » Tue May 25, 2010 9:42 pm
I wonder if the problem is something simple? Did the fitter disturb the dash... he might have knocked the wire on the back of the stereo?
You've Been Bongod
Post
by You've Been Bongod » Tue May 25, 2010 9:54 pm
already checked the stereo thats ok
wormey
Post
by wormey » Wed May 26, 2010 10:36 am
I'd run another wire from the stereo to the speaker without running it through the trim, if it works then the wire in the trim is at fault.
Could the fault be the stereo settings for the speaker control, knocked?
Daz and debs
Post
by bigdaddycain » Wed May 26, 2010 12:05 pm
Sounds like the insulation on that speaker cable has been snagged by trim refitting somewhere along the line.. most probably earthed out to the body now. Try disconnecting the ISO block connector and systematically testing power output on each speaker channel with a test speaker there. Bet ya all 4 are working spot on that end. You'll compromise the sound if you use the other rear speaker to tap into though...dedicated channels should have dedicated signal sources!
You've Been Bongod
Post
by You've Been Bongod » Wed May 26, 2010 9:33 pm
wormey wrote:I'd run another wire from the stereo to the speaker without running it through the trim, if it works then the wire in the trim is at fault.
checked all the wireing so will try the running new wire as speaker is now out so easy try
thanks all for the info
daveblueozzie
Post
by daveblueozzie » Wed May 26, 2010 11:15 pm
Both my rear speakers didn't work. mind you there was none in there anyway.
had to rewire it and fitted some speakers bigdaddy gave me.
Lost without my Bongo.
You've Been Bongod
Post
by You've Been Bongod » Thu May 27, 2010 8:22 pm
all sorted now it was the white block on the iso connector
so if you have changed your head unit then please check you dont bend a prong
Post
by bigdaddycain » Fri May 28, 2010 11:37 am
I bent my prong once...
I consoled my self by strumming my banjo, till the string snapped! TWOING!
wormey
Post
by wormey » Fri May 28, 2010 1:55 pm
bigdaddycain wrote:I bent my prong once...
, brings water to my eyes.
Glad its fixed,
Daz and debs
cheffy34
Post
by cheffy34 » Fri May 28, 2010 10:55 pm
You've Been Bongod wrote:i have had a cat 1 alarm and rear camera fitted this week
Was the alarm pro fitted
You've Been Bongod
Post
by You've Been Bongod » Fri May 28, 2010 11:09 pm
cheffy34 wrote:You've Been Bongod wrote:i have had a cat 1 alarm and rear camera fitted this week
YES PRO FITTED AND ALSO REAR CAMERA FITTED BY THEM
cheffy34
Post
by cheffy34 » Fri May 28, 2010 11:20 pm
You've Been Bongod wrote:cheffy34 wrote:You've Been Bongod wrote:i have had a cat 1 alarm and rear camera fitted this week
dunno then
was gonna say the leccies do funny things when you connect triggers without diodes but a pro would have used them i'd have thought
