white and black wires cut and taped behind front grill?
opp_uk
Post by opp_uk » Tue Apr 27, 2010 11:21 pm
Hi all, I appear to have a 2 core cable with white and black wires that has been cut and consealed behind front grill. the lead looks like its heading down around the corner guide, though when i put a current through it the side light came on??? :shock: any ideas? and on the note of corner guide does anyone kow how to get this thing rewired to work? if i press the button i can hear the motor engauge but nothing happens and i dont have any light from the beacon?
any help much appreciated
cheers
Pete :D
Re: white and black wires cut and taped behind front grill?
Post by Northern Bongolow » Wed Apr 28, 2010 1:39 am
the two wires maybe add on side light wires that have been removed,took the pos and neg from the sidelight!
i did an autopsy on my parking pole as like yours my one made all the noises but no light etc.
the motor you can hear rotates a drum containing the wire for the bulb,that is threaded up a plastic hollow tube which is strong enough to push up the mast but soft enough to curl round the drum,my pipe had brocken in about 4 places,so would not push up the mast,when coming down the wire still rotates around the drum and rips it from the bulb,
a brain surgeon would be handy,with them glasses too :shock:
hope this helps.
daveblueozzie
Post by daveblueozzie » Wed Apr 28, 2010 7:59 am
take a look at this post it might be of use.
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=39960
Lost without my Bongo.
