Temp Gauge Again
David Edwards
Re: Temp Gauge Again
Post by David Edwards » Wed Apr 14, 2010 11:33 am
Right next question,lol, since the bongo shop is out of stock on stats where can I get a genuine one, has anyone bought one recently and can recommed a seller.
Post by missfixit70 » Wed Apr 14, 2010 11:46 am
Nearest Mazda dealer?
David Edwards
Post by David Edwards » Wed Apr 14, 2010 1:13 pm
Nah tried em. guy looked at me like I had two heads, might try another tho,just in case,lol.
Having said that, just phoned Newport Mazda and priced a stat to be sent out to me, genuine (obviously) mazda stat, £18.31 inc vat, not bad at all, will be here Friday he said, next job..fit it, completely flush out system and rad to get rid of any gunk, then a trip to see how it goes. Thanks for the help peeps.
Post by missfixit70 » Wed Apr 14, 2010 1:20 pm
One on ebay - http://cgi.ebay.co.uk/GENUINE-MAZDA-BON ... 45f0d6212e
or ring Ian & see when they'll be back in stock.
DE-OGZ
Post by DE-OGZ » Sat Apr 17, 2010 8:20 pm
DE-OGZ wrote:Hi Peeps
Doin my guage mod tomorrow, reading the fact sheet I may want to put fit 110 ohm resistor so normal running shows as fairly vertical just a psycological thing really (I'll try the 100 ohm first tho)
Cheers - J
Hi all
I have done the temp gauge mod (very clear instructions I might add), now the reason I wanted to do it is so I can see when my V6 is running on the hotter side. I dont think I need an audible alarm just a temp gauge that moves when the temperature goes up or down.
Any how - with the 100 ohm resistor the gauge was close to max, expansion tank quite warm as well (about a needles width or two from the thin line) tried the 110 ohm (2 x 220 in parallel) and it was only slightly cooler on the gauge.
I suspect I am running a bit warm, any ideas on what to do next? Think I really guess i should be getting the coolant changed and a new stat (genuine as everyone suggests). The van was imported at the end of last year so I am not happy about not knowing what kind of coolant is being used anyway.
Still cant stop grinning every time we get to take Snoop out tho :lol:
Any ideas or experiences will be appreciated as usual (I know that a lot of you have probably written replies to hundreds of posts like this over the years but us newer owners, 4 weeks tomorrow for me!, really need your help)
Bongos are GREAT, bongofury is FAB, but you lot are bloomin MMMMAAAAZINNN =D> =D> =D>
Post by Northern Bongolow » Sat Apr 17, 2010 11:22 pm
david please make sure the port in the stat housing is clean.
maxheadroom
Post by maxheadroom » Sun Apr 18, 2010 8:42 am
Northern Bongolow wrote:david please make sure the port in the stat housing is clean.
and the jiggle pin is at the front (top) and the rubber gasket is seated right :D
Keep the Faith
David Edwards
Post by David Edwards » Sun Apr 18, 2010 11:02 am
Thanks peeps, hope this will sort it out.
