sorry fuel guage
karen
sorry fuel guage
Post by karen » Sat Apr 03, 2010 4:43 pm
still having a problem with guage
i have done the extra earth setting as appears in a few of the posts and now rather than nothing at all - the guage is stuck on full
i assume i need to follow the wot i found epicPosted: Sat Apr 14, 2007 6:56 pm post and do the suggestions there
is it easy enough to take the unit off - i assume it is just a case of disconnect the pipes , remove the screws - pull it and have a look?
will there be much leakages from these pipes if i remove them?
sorry for the stupid question - not that grate with car mechanics but sometimes these things turn out to be a lot easier than they appear to me
dreamwarrioruk
Re: sorry fuel guage
Post by dreamwarrioruk » Sat Apr 03, 2010 4:46 pm
you might get a couple of drips out of the pipes when you disconnect them, the sender unit is easy to remove, if your handy with a multimeter you could check the resistance of the float unit to see if thats at fault. it might be just stuck in the top position tho i doubt it.
mike, jo and emma
gmaczbongo
Post by gmaczbongo » Sun Apr 04, 2010 8:56 pm
Sounds like you may have earthed the wrong wire.
If you earth the live wire, you will get a full tank reading.
Just try connecting a wire from the seat post to a cleaned part of the top plate.
Just hold the wire on both parts ans see if the gauge reads properly.
Post by missfixit70 » Sun Apr 04, 2010 8:59 pm
gmaczbongo wrote:Sounds like you may have earthed the wrong wire.
You could be right :wink:
It's the black wire that should be earthed as per this thread - http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=33920
karen
Post by karen » Mon Apr 05, 2010 9:51 am
sorry updated link instead of correct thread
ok i was 99.99% sure but pop out and checked again
it is wired as per your diagram
if i pop a rapidtest on it then the green is registering 5 to6 volts and the black is zero (need to get a new meter though - it's a bit flakey)
if i remove the extra earth and just put the original earth point on then the guage starts to read constant empty - if i reattach the earthing as per diagram then i get full reading
the pipes admittedly dont look as big and scary as i thought - i assume i'm really at stage of remove and have a look (can at least get some photo's of underneath as havent seen any yet)
Post by Doone » Tue Apr 06, 2010 5:20 pm
I don't know if you've seen THIS FUEL GAUGE POST it may help as it describes how to test both the sender and the gauge.
karen
Post by karen » Thu Apr 08, 2010 10:30 pm
yep seen a few and to be truthful - having seen the hoses in the kirsty pics - i think i will remove them anyway and have a peak.
gonna to it at the weekend and see how it goes
