I was gonna put this into a garage to relace the pump and THE SEAL AT THE FRONT OF THE PUMP WHERE IT MEETS THE ENGINE BLOCK.
But i was thinking of doing it myself . I read on here that its just a case of engine at TDC and line up the pump with the timing mark . Then i was gonna get it to a garage to fine tune the timing for the pump.
WHAT I WAS WONDERING WAS :will i get the seal from lawsons diesels cause i dont see them in the club shop? And will it run if i remove the pump and replace it the way i described? where is timing marks for TDC and are they easy to see /adjust?
ANYTHING I NEED TO KNOW?
Should i just forget DIY and put it into the garage?
