Oil change and copper washer
				Scott & Gillian
I'm going to change the oil and filter on the van shortly.
I've read that I should change the copper washer when I do it.
Anyone know what size washer I need before I take it all apart??
I'm a collector of random things. Anything. But not glitter, which is nasty.
www.random-things.co.uk
- missfixit70
Re: Oil change and copper washer
Can't tell you the size, but you could just anneal the existing one - http://www.motorcycle.co.uk/Reference-m ... shers.aspx
				steviebongo
- Tribal Elder
Depends where u get ure filter from if it's a local mazda dealer then the sump plug washer that they use will fit, I know cause i used one of these yesterday on a bongo diesel.Best of luck.
cheers stevie
						cheers stevie
Golly. I bought one when I did my 1st oil change.  Can't remember very well but I think it was a 19mm one, sold in Halfords as suitable for a Vauxhall something or other.  But then I got a Pela pump and all my oil changes since have been done by sucking old oil out the dipstick hole.  Makes the job an absolute breeze and no need to remove the sump plug.  Highly recommended if you've got about £30 to spare and fancy treating yourself.
				bobngo
just measured a spare i have here its :-
material copper
inside diametre 14.5 mm
outside diametre 20mm
thickness 1.5 mm
hope this helps
						material copper
thickness 1.5 mm
hope this helps
- haydn callow
for 50 years now I have always reused the old one, that could mean 20 oil changes on some vehicles....never had a problem.....
				Scott & Gillian
Cheers for the replys everyone!!
Choices choices!!
									Choices choices!!
				kawasaki kid
- Tribal Elder
If you need to get a replacement washer  the one fitted to a Ford Ranger is the same - any Ford dealer should be able to get you one - I fitted one as my van didn`t have a washer  fitted when I bought it.
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
Nice one Kirsty~we do that with (copper) head gaskets on motorbikes stick em in an oven~that's usually with new onesmissfixit70 wrote:Can't tell you the size, but you could just anneal the existing one - http://www.motorcycle.co.uk/Reference-m ... shers.aspx
Regards Ray & Christine
- missfixit70
Triple/R wrote:Nice one Kirsty~we do that with (copper) head gaskets on motorbikes stick em in an oven~that's usually with new onesmissfixit70 wrote:Can't tell you the size, but you could just anneal the existing one - http://www.motorcycle.co.uk/Reference-m ... shers.aspx
 Usually best to anneal new ones, just to make sure.
  Usually best to anneal new ones, just to make sure.You can't polish a turd - but you can roll it in glitter.
