Blanking the EGR valve
PeterP
Post by PeterP » Sat Mar 20, 2010 4:22 pm
I've read several threads on the EGR blanking.
Do you need to blank both ends? and why?
When I was into Land Rovers, we only blanked one end with no issues - the other end was welded !
Re: Blanking the EGR valve
Post by missfixit70 » Sat Mar 20, 2010 4:32 pm
So you blanked the other end by welding it?
I don't think it's imperative you blank both ends, the russians use a 2 rouble coin, but someone tried a simimlar trick with a different coin in the uk which ended up with the engine being stripped to pull all the bits of coin out as I remember #-o
I removed mine entirely, a forum member Nick Skidmore was making up stainless plugs to blank off the turbo outlet along with blanking plates (think he stopped doing them a while ago). I think some have done similar by welding up the outlet pipe from the turbo & removing the rest of the gubbins.
There's a fact sheet in the members area too http://www.igmaynard.co.uk/bongo/member ... ts/EGR.pdf
dobby
Post by dobby » Sat Mar 20, 2010 4:42 pm
Got mine from Allan's
http://www.allansvehicleservices.co.uk/57380.html (half way down page)
Well made and easy to do, usual fiddly rules apply! :D
Allans
Post by Allans » Sat Mar 20, 2010 5:18 pm
If you're blanking to stop the EGR working, you just blank 1 end.
If you want to problems from a split pipe (they are known to split on the weld), blank both ends.
Blanking both ends at once saves having to do it later.
Mattsonics
Post by Mattsonics » Mon Mar 22, 2010 10:23 pm
Probably another dumb question;-
Why would you want to prevent EGR from working?
Wouldn't you want to fix if it's broken?
Matt
Post by missfixit70 » Mon Mar 22, 2010 10:39 pm
Have a read of the factsheet, see if that helps :wink:
