widdowson2008 wrote:That's what I thought, and indeed, it was the very reason I produced that drawing, to show where air could get trapped.g8dhe wrote:Can't air get trapped between the bottom of the radiator and the thermostat ?
Your diagram
shows that it rises upwards, if the thermostat hasn't got an air hole, or it gets blocked if it does have one, then air will be trapped until the Thermostat opens, hence needing to make sure it does open and a hot lower hose shows that it has and that air isn't trapped.
....and then.........
I examined a thermostat very closely (in fact, took one apart). What I found was that not only was the 'jiggle pin' a very loose fit in the main flange, it is also in the direct line of fire from the heater return flow coolant (providing the stat has been correctly fitted). Jiggle pin shaft is 1mm diameter fitting into a 3mm hole - what in engineering terms is a 'piss fit'. I don't think a 3mm hole could be tolerated anywhere else on the pipework. Conclusion? - designed to leak.
As far as 'getting blocked' is concerned, of the 7 stats I have tested, all the jiggle pins were loose (as per a new stat)
When the engine is running, the pump creates a turbulent flow within the stat mixing chamber, which in turn gives the 'jiggle pin' a fair old buffering. Because I cannot physically see inside the housing during normal working conditions, I can only assume that any air trapped below the stat flange will take its easiest route, and that would be through the jiggle pin hole. I hate assumptions, but I honestly believe that this is the true function of the jiggle pin - a bleeding aid. I cannot think of any other possible purpose for it being there. Always open to ideas though.
Most thermostats have a Jiggle pin. Its function is to allow trapped air past a closed thermostat as a build up of air in front of the wax capsule could cause engine damage. The wax capsule relies on coolant to relay heat to operate. If air was surrounding the capsule and the engine was at operating temperature, the stat would remain closed and cause the engine to overheat.
