Bongo Free Top weather seal.
Re: Bongo Free Top weather seal.
Post by mikeonb4c » Thu Mar 11, 2010 12:47 am
rev pete wrote:A Brilliant site for lots of stuff I will check my roof and get a new seal for it. BONGO FURY MEMBERS ARE GREAT Long live the Brilliant BONGO :D
Might be worth contacting Justkampers to see if their interest might be aroused sufficiently to offer a kit for the Bongo seeing as there are so many in UK and many may need seals in the years ahead :roll:
Post by missfixit70 » Thu Mar 11, 2010 1:17 am
I reckon the profile on the top right seals here are more like it - http://www.justkampers.com/shop/type_2_ ... roof-seals - @ 8.5m (I didn't go out in the middle of the night with a tape measure :^o) for @£30 should do it IMO, but I'd measure carefully & order a bit bigger just in case, keep us posted if you go for it, piccies'd be good.
Edit - Just checked the "kits" & the Dormobile roof seal kit http://www.justkampers.com/shop/type_2_ ... 12507.html looks like it's only £25.50, the right length (check & measure 3 times to make sure :wink: ) & profile, tempted myself as mine's looking a bit sorry, have to have a check in day light.
Post by Doone » Thu Mar 11, 2010 2:57 pm
8) Just once or twice. :wink:
Edit - Just checked the "kits" & the Dormobile roof seal kit http://www.justkampers.com/shop/type_2_ ... 12507.html looks like it's only £25.50, the right length (check & measure 3 times to make sure ) & profile, tempted myself as mine's looking a bit sorry, have to have a check in day light.
If this does fit, that's a good find.
Post by mikeonb4c » Thu Mar 11, 2010 3:41 pm
That may indeed be an excellent find. Well done Kirsty =D>
Post by missfixit70 » Thu Mar 11, 2010 9:49 pm
This is the bongo seal, not the best piccy, but it's sort of between two of the Justkampers ones, doesn't quite go out sideways but it's not quite central either
dandywarhol
Post by dandywarhol » Thu Mar 11, 2010 10:09 pm
How wide is the "U" on the Bongo seal Kirsty? JK reckon the Vee Dub seal won't take much more than 4mm wide - the Vee Dub is a flimsy lid.
I'm goning to change mine - it's shrunk a bit and there's a gap at the join - I've also got the "tide mark" above the seal on mine :?
Post by missfixit70 » Thu Mar 11, 2010 10:13 pm
Difficult to tell, just had a quick look (was doing 3 other jobs at the same time :roll: ) & the seal itself bent a bit as I was manoevering it, I'd have to measure properly & possibly have a look at some samples to say.
Post by mikeonb4c » Thu Mar 11, 2010 10:16 pm
Did you happen to notice how the Bongo seal stays in place Kirsty? Does it achieve it without adhesive?
I wonder if it might still be worth asking JustKampers for a view in case they have a connection to manufacturers who make this kind of stuff :roll:
Post by missfixit70 » Thu Mar 11, 2010 10:17 pm
mikeonb4c wrote:Did you happen to notice how the Bongo seal stays in place Kirsty? Does it achieve it without adhesive?
Seems to be a similar kind of grip as the JK ones, may try & ask for a sample piece when I get around tuit.
Post by mikeonb4c » Thu Mar 11, 2010 11:42 pm
Good idea. I'll be interested to hear the outcome (I've a drawer full of round tuits :oops: )
Post by missfixit70 » Fri Mar 12, 2010 8:55 pm
Got a better pic today
it's about 30mm high & 12 mm wide externally & about 4mm wide, maybe just over, on the aft edge.
rev pete
Post by rev pete » Fri Mar 12, 2010 11:31 pm
Brilliant thankyou so very much for your help =D>
Post by missfixit70 » Sat Mar 13, 2010 1:04 am
I had a look through the downloadable wall chart of rubber trim profiles of the company Helen linked to, one or two look close, I've sent them an email with a pic of the profile with sizes & a request for samples of anything they have that would do the job.
rev pete
Post by rev pete » Sat Mar 13, 2010 1:17 am
All I can do is say thankyou again and await your result. I won't contact them myself in case it causes confusion.:o) :D
helen&tony
Post by helen&tony » Sat Mar 13, 2010 5:24 am
That's what I've always done with that company...pick something off their chart. Last time I went I seem to remember that they had a load of books of trim. They won't have something "Bongo Specific", so it's just going to look...or post a 1/2 inch piece...cover the gap with greenhouse tape...and, as I say...order a fair bit more than you think,and a rubber tube to slip in the hollow "squashed" section...your old one may not have had a joiner, but your new one will need it....I've done this job a few times. The new rubber may be stiffer than you imagine, so do the job on a hot day, leaving the rubber in the sun for a while, and fit and re-fit (shuffle) the rubber....it's easy to fit, cut , and find you've cut it short....
